Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Closed Thread
LinkBack Thread Tools
Old 03-27-2005   #76 (permalink)
Leets
Super Member
Leets is an unknown quantity at this point
Quote:
Originally Posted by robbclark1
The upper mounts will fit. As far as I know, anything EP3 will fit because they are probably going to be designed for the 03-04. After 04 Honda changed som estuff. Why do you want EP3 struts? Are they oem struts? If so, they are not going to be much better than your current shocks.
I'm just checking to see if EP3 coilovers will work without modifying or drilling anything on 03+ non-si vics. Thanks for the info.
__________________
It isn't a great night unless you almost end up dead.
Leets is offline
Sponsored Links
Old 03-27-2005   #77 (permalink)
Xenin
Superior Evolutionary Element Destined-factor
Xenin's Avatar
Xenin is an unknown quantity at this point
Send a message via Yahoo to Xenin
Quote:
i was wondering if the DSpecs for the Si would fit an 03 coupe.
Xenin is offline
Old 03-28-2005   #78 (permalink)
JesterMasque
...ever grinning...
JesterMasque's Avatar
JesterMasque is an unknown quantity at this point
Send a message via AIM to JesterMasque Send a message via Yahoo to JesterMasque
I know someone posted earlier with the same case as mine but...
I got an 02 EX dropped with Eibach Sportlines just about 2"+. Someone rec. Tokiko's to the guy but didn't specify which ones (the Blue's or the D-Spec's). I don't plan on SERIOUSLY dragging this car out, but I want a nicer ride but also performance for if I ever do need it. I mean, the Sportlines already do a hell of alot compared to stock, but I know that it could be alot better with the aftermarket shocks. Also, how much should I pay for either the Blue's or the D-Spec's? I don't want to get ripped off... Thanks!
__________________
1997 Sandstone Silver Buick Riviera Supercharged
SOLD
2002 Silver Honda Civic EX Coupe
Tenzo R Rallye-2 Seat
Base RSX Shift Knob
Redline Goods Custom Shift Boot
DC Sports Short Shifter
AEM SRI
Neuspeed Strut Tower Bar
Eibach Sportline Springs
7thGen.MT.C.
JesterMasque is offline
Old 04-05-2005   #79 (permalink)
Xenin
Xenin's Avatar
OEM 03 EP3 struts fit 03 EM2? just wanted to confirm that.
Xenin is offline
Old 04-05-2005   #80 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
Quote:
They should fit, but they won't look right. They have different spring lengths. I suggest not getting them. Why "upgrade" to OEM anyway?
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline
Old 04-05-2005   #81 (permalink)
nindoo
Why is my vagina bleeding?
nindoo has a spectacular aura about nindoo has a spectacular aura about
Will Konis give more ride comfort than Tokico hps, on neuspeed sports. Or are both set-ups hard as nails?
nindoo is offline
Old 04-06-2005   #82 (permalink)
Xenin
Xenin's Avatar
well theres a guy selling 03 EP3 struts with konis in them so thats why i was wondering but i've decided not to buy them. i know the konis would fit cuz its the same part# except for the 50/55mm difference. i was planning on using neuspeed sports. i'm thinking of calling up tokico and finding out what the size of the crashbolts are on the 02EP3 DSPECs are.
nindoo, i believe konis are better than tokicos and tokicos are better than OEM.
Xenin is offline
Old 04-06-2005   #83 (permalink)
robbclark1
robbclark1's Avatar
Next time be more clear . The konis with EM2 springs will work as long as the struts are 14mm and the Konis are the right size.
__________________
Suspension FAQ
Autocross FAQ
Old 04-06-2005   #84 (permalink)
Xenin
Xenin's Avatar
ahh, sorry about that. i've got an 03 EM2 and from reading a bit at ephatch.com late 02 and 03+ EP3s are 16mm crash bolts. i'm just gonna get konis on my own struts with neuspeed sports and of course a camber kit. thanks for the info though, well appreciated.
EDIT - will i need a front camber kit as well with the neuspeed sport drop? i know i'll def. need a rear camber kit but i'm unsure if the front is needed since the drop is not slammed.
Xenin is offline
Old 04-06-2005   #85 (permalink)
robbclark1
robbclark1's Avatar
Yeah, you need 16mm bolts. Sorry i thought you had an 01. It is suggested. They are only $20 so why not? They wil allow more adjustability than the OEM crash bolts.
__________________
Suspension FAQ
Autocross FAQ
Old 04-06-2005   #86 (permalink)
Xenin
Xenin's Avatar
excellent. thanks rob.
Xenin is offline
Old 04-06-2005   #87 (permalink)
nindoo
So there is no shock that is better than another when it comes to ride comfort for daily driving on lowering springs? The roads are quite horrible here don't want to feel like my is breaking every time I hit a bump.
nindoo is offline
Old 04-07-2005   #88 (permalink)
Xenin
Xenin's Avatar
Quote:
i know how you feel.
Xenin is offline
Old 04-07-2005   #89 (permalink)
nindoo
I'm just a little trustrated, I thought I had my lowering strategy all figured out.
I think if I get a spring which is softer with a performance shock I wont feel the bumps as badly as with stiffer springs like the neuspeed sports.
nindoo is offline
Old 04-07-2005   #90 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
The Hp's will be softer, as Tokico is known to be on the "softer" side of performance dampers... But both will be noticeable firmer then OEM. You may want to look at the D-Spec dampers, as you adjust both bump and rebound at the same time (Great for a street damper, not so much for a race damper). what this will allow you to do is Minimize the Bump Rates giving you a softer ride... and when you want a bit of performance you can adjust the rebound to where you need. Unfortunatly because you adjust both rebound and bump at the same time, you'll end up with a comprimise between Both for handling performance. Rebound primarly influences corner entry and exit handling... Bump deals more with ride quality. so as you increase rebound to adjust handling, you'll also be increasing Bump... too much bump valving and you run in to the possibiliy that when you hit bumps the tire may bounce off the ground (due to the higher bump setting not letting the spirngs do their jobs)... So you can see that performance wise you'd have to make a comprimise... But for a street damper, being able to reduce bump for ride quality is a good thing.
Oh ya, I'm not sure if the D-spec or HP has softer valving (Overall)... You may want to contact Tokico and ask.
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline
Closed Thread
Tags
automotive , ceruttis
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
