Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-26-2004   #76 (permalink)
nindoo
Why is my vagina bleeding?
nindoo has a spectacular aura about nindoo has a spectacular aura about
VNlilMAN
Is the only difference in installing these D2's as oppose to the Hayames, is the brake line brackets? Do you need to weld the brakets?
You had me all hyped up about the Hayames, but I'm guessing urban imports has the D2s in stock.
Why do you need to get an alignment after you change the suspension?
Why can't the world be a better place and let Urban Imports have the Hayames in stock!!!
nindoo is offline   Reply With Quote
Sponsored Links
Old 04-26-2004   #77 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
VNlilMAN will become famous soon enough VNlilMAN will become famous soon enough
Send a message via AIM to VNlilMAN
Well not sure if you'd consider it part of installation but the way you adjust the height is different. And the D2s also dont come with rear top mounts so you need to use the stock ones. The front installation is pretty much the same except yeah, the brake line bracket. You dont need to weld it, just place the bracket on the bolt before you tighten it up.
UrbanImport just ran out of D2s as well. They should receive another shipment in like a month. I think they're getting the hayames really soon tho.
Anytime you lower the car, your going to have more negative camber. This is pretty much a guarentee. Also things arent going to be lined up exactly the way it was before you touched the suspension, this will also change the alignment. Especially when you put in new struts, the strut design isnt going to match the stock strut designed 100% so that will throw the alignment off big time depending on how different it is. But ya its just something that recommend anytime you touch the suspension ESPECIALLY when you change the shocks/struts.
VNlilMAN is offline   Reply With Quote
Old 04-26-2004   #78 (permalink)
nindoo
So if I get the hayames and plan on dropping my car approximately 2 inches, do you think I'll need a camber kit, or I could do without one ?
Do you think its a bad idea for me to go the honda dealer to have my alignment done after I install the suspension? The reason I ask is because they owe me one free alignment.
Old 04-26-2004   #79 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
yeah you probably will need one for 2". Just the rear(since the fronts already come with it)
Eh you can try but they probably wont do it since its a lowered car... I went to discount tires and they hassled me saying it wouldnt fit on their rack. but ya doesnt hurt to try, only thing is they might give you a lecture and tell you how you voided your suspension warranty
Old 04-27-2004   #80 (permalink)
nindoo
Will they also give me a lecture if I have negative camber?
There is a garage that modifes cars, I'll bring it to them, and I guess they will also let me know if the installation is good or not.
Is it better to drop it less and get use t the car first? Maybe an Inch and a half.
Anything I need to watch out for when setting up the kit? Adjustments and stuff?
Old 04-27-2004   #81 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
a garage that modifies cars will most likely not have a wheel alignment machine. You have to take it to a wheel shop most likely, but ask the speed shop where they take their cars. No one should give you a lecture about camber, just tell them to shut up and align the car to what specs you want. Just take it to Honda and say you want -.5 camber front, and -.75 camber rear and 0 toe all around. that isn't perfect OEM but it is well within specs.
put everything on, let it settle, see how you like the drop and adjust accordingly to fit your needs. A week or two with negative camber won't kill anything. Make all your adjustments before you get it aligned. Make sure there is NOT a lot of preload on the front or rear springs. Preload (changing the springs height) does not change the height of the car on Hayames. Turning the shock in and out of the mount changes the height
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 04-27-2004   #82 (permalink)
nindoo
Soemone told me I could keep the height stock, and get the alignment done and then adjust the height lower afterwards. Is he right?
What does it mean to have a a .5 camber in the front and a .75 camber in the rear. Does stock come with 0 camber?
Old 04-27-2004   #83 (permalink)
nindoo
Sorry for all the questions I am a novice.
Old 04-27-2004   #84 (permalink)
robbclark1
robbclark1's Avatar
No you can't keep stock height with coilovers. They automatically lower your car. No you don't set it high, get it aligned and then lower it. That is just dumb and tell that person he needs to go find out about vehicle dynamics. If you lower or raise you move the pivot points thus changing camber and toe. Every time you adjust the coils you should get an alignment, but it isn't necessary unless something is way out of wack or you changed the settings very severely.
yes factory settings is 0 camber, but 0 camber sucks for turning. -.5 and -.75 will give you a little inner tire wear but not much, but it will help with turning. why lower if your suspension settings suck right?
__________________
Suspension FAQ
Autocross FAQ
Old 04-27-2004   #85 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Quote:
7gen03, Glad you brought that up. I've been meaning to add it to my review... They meant to make it like that. Reason being when you autocross you usually want as much negative camber as well as POSITIVE CASTER. The way the plates are positioned you get two in one basically. If you want proof here it is..
"If you are a competition driver who frequently runs autocross, track or road race events, you'll typically want the maximum negative camber, maximum positive caster and most aggressive toe settings available from the car and permitted by the competition rules. If the rules permit, aftermarket camber plates and caster adjustments are good investments."
taken from http://www.tirerack.com/tires/tiret...neral/align.jsp
I'll go further in depth later...
__________________________________________________ __________
Thanks for your reply, regarding your question about ES1, actually our
pillowball top mount is designed not only for adjust camber but also
including adjust caster, according the pictures that you sent to me,
this is
correct , the newest and also the best setting , such as BMW, BENZ,
and
porsche. The caster angle will be obliquer than normal street purpose,
and
also the veer of steering will be more accurate.
You still can't adjust them on the fly. Regardless of how they're positioned, you can't get the toe straight thanks to the steering arm. You will have mad toe in and the car becomes undrivable. This is speaking from experience, then numerous phone calls to everyone who had camber plates available at the time (Tein, JIC, Hotchkis, and Ground Control) to try and figure out what wasn't right. You can't make on the spot adjustments without doing the whole alignment over. So even if you can put extra caster in, you still need to set it, align it and leave it.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 04-27-2004   #86 (permalink)
robbclark1
robbclark1's Avatar
Regardless of the car changing the camber will change the toe, it just happens that the new steering arm makes it more dramatic.
__________________
Suspension FAQ
Autocross FAQ
Old 04-27-2004   #87 (permalink)
Boilermaker1
Jap-Euro Fusion
Well yeah, you used to be able to still drive it, it'd just feel loose. Now you can't.
Old 04-27-2004   #88 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
I wonder if changing the caster helps out with the toe issue? example if positive camber gives you toe-in would positive caster give you toe-out, thus helping that out a bit?
Old 04-27-2004   #89 (permalink)
robbclark1
robbclark1's Avatar
iJudging from the stock suspension Negative caster will give you toe in and positive caster will give you toe out, like you said. Unfortunately we don't have much room for caster play unless you get a caster plate and possibly cut your strut housing. hmmm limitless opportunities to mess with this, just no $$, time or track time. I don't know how much caster will help though. Someone will have to try it.
__________________
Suspension FAQ
Autocross FAQ
Old 04-27-2004   #90 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
^^^ Just remember Robbclark and Boilermaker, if you want to remain in STS The center clearance hole may not be modified.
Rule 17.8 Section C.
other wise, How many people here acutally race their car or even care how much camber/caster/toe they have. most will just have the car aligned with in factory specs and call it a day. The rest of us will just deal with the little problems because we want that last tenth on the track.
Zzyzx is offline   Reply With Quote
Tags
2001 , civic , coilover , coilovers , d2 , good , honda , install , lowest , put , racing , review , reviews , shocks , suspension
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
