Spring
Old Feb 19, 2004
marc-111's Avatar
marc-111 is an unknown quantity at this point
Spring
would the civic 2001 sedan coil spring fit to 2004 civic SI? they both got Control-Link MacPherson Strut Front Suspension and Reactive-Link Double Wishbone Rear Suspension thnx!
Old Feb 20, 2004
Zzyzx's Avatar
Autocross Junky
No, they are different lengths.
Old Feb 20, 2004
HondaLuver's Avatar
Its a celebration bitches!
^^^ what he said....
the si has a 5 lug bolt patter, its the same as a rsx or type S, you can get one of those suspentions.
Old Feb 20, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Bolt pattern doesn't have much to do with the suspension. And the new Si will suck worse than the old ones. Somewhere along the line it gained 140 lbs, and it has the Base RSX brakes, not the S brakes. So its still overweight and underbraked. But get it now if you really want it, 04 is the end according to Temple of VTEC.
It won't fit because the Si springs are longer in the front and shorter in the rear. Do a search, I've seen the dimensions posted.
Old Feb 20, 2004
marc-111's Avatar
ah ok, thnx!
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
