Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-10-2004   #1 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
VNlilMAN will become famous soon enough VNlilMAN will become famous soon enough
Send a message via AIM to VNlilMAN
Full Review on Hayame Coilovers
GroupBuy $650 SHIPPED through www.UrbanImport.com
How to adjust the height on the hayames
When I heard these were out I knew I had to get them. It comes with tokico shocks, 3 locknuts(opposed to 2) and upper mounts all for only $650 shipped from www.urbanimport.com. The main thing that separates this from teins, b&g or kw is the 3 locknuts.
Advantage of 3 locknuts: You know how most coilovers, lower you go worse the ride. Well that’s because with coilovers such as tein, you adjust the spring perch(the thing the spring sits on) to lower the car. When you lower the car 2" with tein's your basically compressing the shock 2" all the time, which puts added stress on it. With the hayames you’re not adjusting the perch but the actual length of the strut. This allows the shock to retain full stroke and gives you the same ride at 2" as you would at stock height.
Top Mount: This allows ease of installation. Basically just take out the old struts and put in the hayames. No need to worry about compressing the springs, what parts you need from the stock struts, whether your 01 needs new mounts, etc... It just makes installation a breeze.
Also when receiving the coilovers I saw something I didn’t see in the pictures. There isn’t a camber plate BUT they made the hole for the top bolt wider so that you can adjust the camber that way without using a (front) camber kit.
Another thing is they have 'spring isolators'. People with teins or b&g sometimes complain about clanking noises. The spring isolators eliminate the noises often found with coilovers.
There are so many little details hayame paid attention to. It may not have damper adjustability but it has all these other features that the $1200 coilovers don’t have. All for $650, you can’t beat it... Best bang for buck hands down.
Ok so I finally got the fronts on. Right now i have the fronts at 2.25" and the rear at 2.5"(basically exactly the same as neuspeed race). Drove my car to work(the roads are really badd and I practically memorized the streets so it put them to the test) and I have to say they ride really nice. There's a couple places where I cringe going 15mph but with the hayames I can take them at 35mph without having to. The rear is slightly softer than what i'm used to but i'm sure adjusting the preload on the springs will fix that(just raise the perch up to compress the springs more). I'll probably play with that tonight if I can and will probably drop it down so that I tuck in a week(cause my dad has to use my car on thursday). I should probably be going down to a 2.5-3" drop eventually with my 18s. Oh and best of all NO MORE BOTTOMING OUT!!!
I highly recommend getting them from Michael at www.urbanimport.com. Great service and awesome to work with. Fast shipping too, got them 2 days after he received my payment.
VNlilMAN is offline   Reply With Quote
Sponsored Links
Old 01-10-2004   #2 (permalink)
armieo
< My future wife.
armieo's Avatar
armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold armieo is a splendid one to behold
Send a message via AIM to armieo
no damper adjustability..... so that means the ride quality is permanently set? how is the quality by the way?
armieo is offline   Reply With Quote
Old 01-10-2004   #3 (permalink)
BlackSI
Platinum Member
BlackSI is an unknown quantity at this point
once u get it all on can u tell me the difference between the ride on the race springs and the hayames?
BlackSI is offline   Reply With Quote
Old 01-10-2004   #4 (permalink)
Mr.Modify
Mr.Modify's Avatar
Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all Mr.Modify is a name known to all
Send a message via AIM to Mr.Modify Send a message via Yahoo to Mr.Modify
sweet! looks like i'll be getting some hayames pretty soon then. i hope they fit the 04
Mr.Modify is offline   Reply With Quote
Old 01-10-2004   #5 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
ya no damper adjustability but for $650 you cant really ask for much. tein basics which run $900 and b&gs that are $1200 dont offer damper adjustment either. b&g's are "self-adjusting" but all shocks are basically self adjusting.
Ya i'll try to give my best comparison after I finish the install. Only if i had more time today. Should have time to finish tomorrow tho.
Old 01-10-2004   #6 (permalink)
KeNsHiN
LEVA
KeNsHiN's Avatar
Send a message via AIM to KeNsHiN
^thanks for the review.....i really need to replace my ground controls and stock shocks!
__________________
*Sig removed because over size limit*
KeNsHiN is offline   Reply With Quote
Old 01-10-2004   #7 (permalink)
armieo
< My future wife.
armieo's Avatar
is it just me or does it seem like the wheelgap on the fronts of our cars is bigger than the rear riding stock?
Old 01-10-2004   #8 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Any clues as to the spring rates? Just wondering... it doesn't matter to me all that much since I've got my mind made up, but for that price, if they're stiff enough to be considered race-worthy, thats a hell of a start-up deal.
This is originally a JIC Magic feature, but yes... it basically allows the ride to remain the same regardless of how low the car is, and doesn't waste your suspension travel. You will have increased travel over the coils with the adjustable spring perch design, and you should probably make sure that you leave more clearance than you think is neccessary at low ride heights, then lower it incrementally if possible/desired.
Boilermaker1 is offline   Reply With Quote
Old 01-10-2004   #9 (permalink)
JayFReaZy
Ultimate Member
Very nice write up VNlilman . Since reading your review, I might actually be thinking about getting a pair oppsed to the b&g's or tein basics. Since each of them are 890 shipped, I would save a significant amount of money by going with the hayame's for 650. Only thing that scares me now is that no one has had these coilovers or used them for a long period of time corect, so no one knows its quality over time. Tokico is a good brand, and should be decent. Either way, nice review, let us know how the ride feels after all 4 have been installed. Nice work!
JayFReaZy is offline   Reply With Quote
Old 01-11-2004   #10 (permalink)
DogstyleEX
Diamond Member
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
Send a message via AIM to DogstyleEX
01-03 Civic 6KG Front/8KG Rear
is the spring rates found on gbc.. they are the same company vnil is talking about btw. search for hayame..
someone compare this to the teins and kw's
DogstyleEX is offline   Reply With Quote
Old 01-11-2004   #11 (permalink)
DogstyleEX
Diamond Member
DogstyleEX's Avatar
ok.. never mind.. these are teins
6.0K/8.0K-336LBS/448LBS
KW's
Type II (DC5,EP3) 350F/500R
3 locknuts, these are my coilovers..
Old 01-11-2004   #12 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
Ya as stated above, spring rates are 6kg front and 8kg rear. You can go stiffer by getting the RSX ones. Those are 8kg up front 10kg rear but ya you need to do some modifications(new tie rods, shaving rear mount, etc...). Most coilovers for our cars are in that range tho..
Hayame: 335/447
tein basic: 336/448
tein ss: 336/448
KW 2: 350/500
True no one has used these for a long time but i'm sure they'll last. The shocks are made by tokico and also you are using stiffer spring rates BUT your not putting as much stress on the shock because of that 3rd locknut.
DogstyleEX, yours are to'ser or something like that right? I remember you posting about them before.
Old 01-11-2004   #13 (permalink)
Dainfamous
Senior Member
Dainfamous's Avatar
Dainfamous is an unknown quantity at this point
Send a message via AIM to Dainfamous
which is good? TIEN or Hayame..still deciding on wat to get..
Dainfamous is offline   Reply With Quote
Old 01-11-2004   #14 (permalink)
VtecIvIc
Member
VtecIvIc's Avatar
VtecIvIc is an unknown quantity at this point
hey VNlilMAN..how are u getting it 650 shipped?..cuz on the site its says to ship to cali in my area which is some what near la..it cost $100 for standard shipping
VtecIvIc is offline   Reply With Quote
Old 01-11-2004   #15 (permalink)
xmeeksx
Senior Member
xmeeksx's Avatar
xmeeksx is an unknown quantity at this point
Send a message via AIM to xmeeksx
how do you know the the shocks are made by tokicos?
xmeeksx is offline   Reply With Quote
Tags
07 , 2002 , 2004 , civic , coilover , coilovers , damper , dezdod , hayame , hayames , hayme , lower , motorsports , review , si , suspension
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
Megan Racing coilovers...update after 10 days, post 24
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
