Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Suspension Performance
Suspension Performance Post Suspension related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-15-2004   #61 (permalink)
dragoon
Post Master General
dragoon's Avatar
Send a message via AIM to dragoon
I was one of the 2 that got the Hayame coils directly from SPW. They're great! To remove this ad, register today for free or log in if already registered!
dragoon is offline   Reply With Quote
Sponsored Links
Old 01-15-2004   #62 (permalink)
ImPulse
ImPulse's Avatar
ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse ImPulse
will i need new struts? dont oem civic struts suck? idk.. somethin like that, i dont know anything about lowering a car :x
ImPulse is offline   Reply With Quote
Old 01-15-2004   #63 (permalink)
robbclark1
Retired suspension supermod.
robbclark1's Avatar
robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold robbclark1 is a splendid one to behold
Send a message via AIM to robbclark1 Send a message via MSN to robbclark1 Send a message via Yahoo to robbclark1
Impulse, read the FAQ in my sig. Coilovers are an adjustable spring with an integrated shock. Before you buy anything, please do your research. Suspension stuff is expensive and you don't want to regret buying something that you don't like.
__________________
Life isnt a test drive, gotta live a little. (02fpcivic)
Suspension FAQ
Autocross FAQ
If you pretend that cars are moving cones, then the roads become your personal autocross course.
I live my life 1 cone at a time, for those 70 seconds or less, I'm free
Thanks to ALPHSTER for the sig!
robbclark1 is offline   Reply With Quote
Old 01-15-2004   #64 (permalink)
gh0st
TAQUITOS!!!!
gh0st's Avatar
gh0st is a jewel in the rough gh0st is a jewel in the rough gh0st is a jewel in the rough gh0st is a jewel in the rough
so just to clarify, are you feeling every little crack and pebble in the road?
gh0st is offline   Reply With Quote
Old 01-15-2004   #65 (permalink)
xmeeksx
Senior Member
xmeeksx's Avatar
xmeeksx is an unknown quantity at this point
Send a message via AIM to xmeeksx
got mine today but i wont be installing it anytime soon since its cold and i dont have a garage. from the looking at the coilover it looks like hayame put a lot of thought into making these. the 3 lock nut is a bit confusing. what is the bottom one for and how does the other two adjust ride heigh by lowering the whole structure and not just the spring? i tried playing around with it and it seems that the only thing that goes up and down is the spring itself.
xmeeksx is offline   Reply With Quote
Old 01-15-2004   #66 (permalink)
tripledoublegs
Euro-Spec
tripledoublegs's Avatar
tripledoublegs is just really nice tripledoublegs is just really nice tripledoublegs is just really nice tripledoublegs is just really nice tripledoublegs is just really nice
Send a message via Yahoo to tripledoublegs
I bought them right now. Hopefully I'll have them by monday. Do I have to do my alignment right after I install the suspension, or can I wait a bit?
tripledoublegs is offline   Reply With Quote
Old 01-15-2004   #67 (permalink)
xmeeksx
Senior Member
xmeeksx's Avatar
what are the nuts and bolts used for that came with it
Old 01-15-2004   #68 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
VNlilMAN will become famous soon enough VNlilMAN will become famous soon enough
Send a message via AIM to VNlilMAN
I'm not feeling every crack/pebble on the road but my car does feel cracks. this is due to my 18s tho. I used to cringe going 15 mph in certain dips but now i can go 35mph without feeling it much. So ya the cracks depends on your tires but bigger things the coilovers will help with.
xmeeksx, if you read a few of my posts you'll see what everything is. I explained it a couple times. To sum it up, the bottom one is the one thats going to be used to lower/raise the car. The other two are simply there to keep a preload on the springs. Right now it may only seem like the springs move up down but if you put more pressure on it say like a 2 thousand pound car, than you'll see the shocks/springs compressing.
tripledoublegs, its better to wait a bit. Play around with it for a couple weeks and see what setting you like it at because once you adjust it again the alignment is going to be off. So ya just set it and make sure thats what your going to set it at, then get an alignment
VNlilMAN is offline   Reply With Quote
Old 01-15-2004   #69 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
the nuts are used for the top mounts... You can use your stock ones or you can use the ones it came with. I never got any bolts other than the ones that are attached to it.
The two tools that came with it.. thats what your going to use to tight/loosen the locknuts. Just tighten things by hand first than use the two tools to make it even tighter
Old 01-16-2004   #70 (permalink)
xmeeksx
Senior Member
xmeeksx's Avatar
thanks for the info vnlilman
Old 01-16-2004   #71 (permalink)
dezod
7thgen Power Maker
dezod's Avatar
dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold dezod is a splendid one to behold
Send a message via AIM to dezod
Quote:
Originally posted by UrbanImport
I would like to know how he plans on doing this for several reasons:
1) Hayame was backorderd on the 01 Civic application from August to November. I checked with all the Hayame distributors trying to find this application during that time and everybody was sold out. In November Hayame got ~20 sets of the 01 Civic in. We bought 15 of those. Since then we have also had 2 sets shipped to customers directly from Hayame. I talked to them this afternoon and they have 1 set left. This means there have only been 2 sets bought by other distributors unless they still have some left over from before August which I doubt but I guess it is possible. I think we have 6 sets in stock right now. Hayame doesn't know when they will be getting more 01 Civic in but they aren't back in production so saying they started making them tomorrow it would take 2 weeks to manufacture and prepare to ship then another 3-5 weeks to ship from the factory.
2) Our rep could find no record showing that Dezdod buys from them or that they are an authorized Hayame dealer which means the 1 yr warranty we offer on our kits is not valid will not be honored if purchased through someone who is not an authorized dealer.
We have the coilovers in stock, they ship out the same day your order is placed, no group buy needed and have a warranty.
Hey Mike,
We are dealing with Hayame's direct USA exclusive master distributor, names need not to be revealed. (not necessary) We have a dealer account with them that we set up shortly after the SEMA show. I spoke to 2 different reps there and they both confirmed that 2 weeks ago they had several in stock, so I think you need to find facts before jumping to conclusions with accusations, or confront the source. No hard feelings though, I know it is all about the sales.
Edit: I am merely testing interest at this point to see if this is even worth it, hence the post in GB wanted, where VENDORS of this site can generate interest fro GBs. Besides, what your doing is a on here. Pay the dues and support the site. Besides, we are quite legit, our rep, service and quality speaks for itself. Thanks for your time.
Paul
Dezod
__________________
Constantly redefining the 7thgen Civic's performance... Dezod Motorsports.
7thgen Dedicated Section
Dezod Myspace
W: www.dezodmotorsports.com
P: 716-362-8771
E: sales@dezod.com
Aim: Dezod mtrsprts
dezod is offline   Reply With Quote
Old 01-16-2004   #72 (permalink)
joedc5
Senior Member
joedc5 is an unknown quantity at this point
Hi all, I went to put the HAyame system on and the fronts bolted right but the rear is giving me trouble.The bottom of the strut that you bolt into through the control will not fit in space in the center of the control arm. In other words I have to shave about 2-3 mm off the Hayame strut on the end that is not threaded to make it fit onto the rear control arm. Why is this happening? Did anyone else have this problem?
Joe
joedc5 is offline   Reply With Quote
Old 01-16-2004   #73 (permalink)
VNlilMAN
The Standard One
VNlilMAN's Avatar
Its possible you got rsx or even ep3 ones... thats the only thing i can think of.
Old 01-16-2004   #74 (permalink)
xmeeksx
Senior Member
xmeeksx's Avatar
is there a manufacturer's code for the 7th gen civics so i can make sure mine is for the right application. i wont be installing these for some time thats why
Old 01-16-2004   #75 (permalink)
UrbanImport
Senior Member
UrbanImport is an unknown quantity at this point
Send a message via AIM to UrbanImport
Quote:
Originally posted by dezod
Hey Mike,
Paul
Dezod
Paul,
I apologize, I didn't mean to reflect negatively on your business ethics. I hear complaints about companies all the time from my customers but have never heard any complaints about your company. When I talked to Hayame they had no record of you ever placing an order with them, that’s why I was confused as to how you were getting them. You are correct in stating that 2 weeks ago they had "several" in stock. That was 2 weeks ago, they have since been sold. I know from both a vendor and customers point of view it is frustrating to be sold something that is not in stock.
As far as my presence on this site I came here after a customer sent me a link to a thread where people were asking questions about the Hayame coilovers. I answered their questions and people bought the product from me. I'm sorry if you feel I have been blatantly advertising as I don’t feel I have. I admit I have generated sales from this site but have never felt the need for a group buy. If you think I should be paying fees for being here let me know what you think is fair and who to send it to.
Michael
__________________
michael@urbanimport.com
919-544-4140
UrbanImport is offline   Reply With Quote
Tags
07 , 2002 , 2004 , civic , coilover , coilovers , damper , dezdod , hayame , hayames , hayme , lower , motorsports , review , si , suspension
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Official Suspension Drop Pictures Post
Do It Yourself Spring Install - Detailed Info & Pics
Full Review on Hayame Coilovers
SHOCK/DAMPER INFORMATION....Stop posting the same fricking questions!
FULL REVIEW ON D2 COILOVERS!(Updated 4.20.04)
NEWBIES READ!!! IMPORTANT!! Suspension FAQ and TORQUE SPECS!!!
Megan Racing coilovers...update after 10 days, post 24
PLEASE READ: 2K1 Suspension Replaced
I'm gonna pimp slap the next person who asks if they need a camber kit.
Tie Bars and Sway bars
Site Supporters
aluminum radiator
Honda car spoilers
