Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-30-2003   #1 (permalink)
orion_squall
Diamond Member
orion_squall is just really nice orion_squall is just really nice orion_squall is just really nice orion_squall is just really nice orion_squall is just really nice
Post DIY caliper painting summary
Before I start this summery I would like to thanks all memeber who gave pieces of information in "caliper painting". Now I would like to make a full summary of "caliper painting" DIY.
I hope this will be usefull for new users.
thank for the member who supplyed the rotor picture so I can modify for this DIY
Item needed:
1. wheel wrengch @ 108N.m (1 [N] =1 [Kg] * 9.8 [m/s^2])
2. engine enamel (duplicolor) with heat resistance of 500F. 1200F if you want, but 500F will do.
3. thin brush from 1 dollar store
4.newspapers
5.masking tape
instruction:
1. release wheel nut, but let them stay on bolt
2. jake up the car
3. release the wheel
4. if you are painting the left caleper, rotate the steering wheel clockwise (this will need car started up and obviously not press the gas since the car is jacked up). This will expose the whole caliper profile.
5.mask the whole area of the fender near.
6.mask the area behind the wheel disk
6.put a little strip of paper between brake pad and disc (important, no paint should go betweeen pad and disc)
7.cover the whole brake disc
8.see pic for detail which need to be covered. Area circled in red shall be covered, the blue line represents the little stip of paper which sahll cover the area BETWEEN caliper and disk
9.once they are all covered, paint it.
10. for little unpainted small area, spray paint on brush, then paint the area with brush.
orion_squall is offline   Reply With Quote
Sponsored Links
Old 05-04-2003   #2 (permalink)
Staticfree
Member
Staticfree is an unknown quantity at this point
Here's a pic of what it will look after painting.
http://www.7thgencivic.com/memberrid...php?photo=3716
Instead of sparying directly on the caliper, I sprayed the paint into a bowl, and used a brush to paint it on.
Here's a picture of the paint I used:
http://www.7thgencivic.com/memberrid...php?photo=3717
__________________
Nothing is truely unique. Show me something "unique" and I'll show you where it was copied from.
Staticfree is offline   Reply With Quote
Tags
02 , brake , caliber , caliper , calipers , calliper , civic , diy , drum , g35 , honda , paint , painting , rotor , spray
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
