Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 04-03-2003   #1 (permalink)
dragoon
Post Master General
dragoon's Avatar
Send a message via AIM to dragoon
Lightbulb DIY: Wheel Curbage Repair-pics, not 56gay friendly
The following is a variation on a technique I found from the Audi forums, this is in no way my own DIY.
Parts Required (I had 4 heavily damaged wheels, so this was what I used):
(1) tube BONDO spot putty
(2) cans Dupli-Color Wheel Paint (Gunmetal in color)
(2) cans Dupli-Color Wheel Paint (Clear)
Masking Tape
Index Cards
Simple Green or equivalent cleaner/degreaser
(1) can gap-filler primer, but regular primer is fine
300 Grit sand paper
500 Grit sand paper
There's paint thinner in this pic. It was for cleaning, but simple green will do the trick also.
Clean the wheels thoroughly, inside and out if you plan on totally repainting them.
Use a plastic spreader or card such as an old driver's license to fill in the gaps with the spot putty.
I did not mask off the tires in this step. I dont think it's necessary. However you may want to mask off other parts of the wheel that you don't plan on painting.
Let the bondo dry for a fair period of time, 30 minutes or so.
Sand down the bondo until it looks AND feels smooth.
Your typical primer job, only primer the parts with bondo, because the primer is only there so the paint has something to grip on. In the case of repainting the entire rim, just lightly sand the surface of the rim (make sure to have degreased and dewaxed it as well), you won't need primer.
Sand down the primer if you really need to, and paint. Do not spray the clear coat too soon, or you will get bubbling like this guy. Also, don't spray the clear coat too late, either. After 30 minutes is good, but before 1 hour.
And the finished product. I might post mine when I finish painting tomorrow.
dragoon is offline   Reply With Quote
Sponsored Links
Old 04-03-2003   #2 (permalink)
666
Platinum Member
666's Avatar
666 is an unknown quantity at this point
Excellent idea!
666 is offline   Reply With Quote
Old 04-03-2003   #3 (permalink)
Connie
Abercrombie And Fitch
Connie's Avatar
Connie is a jewel in the rough Connie is a jewel in the rough Connie is a jewel in the rough
Send a message via ICQ to Connie Send a message via AIM to Connie Send a message via Yahoo to Connie
That si a great idea! I would get mine powder coated after doing the puddy though.
__________________
2007 BMW Z4 3.0si Coupe . Premium Package . Sports Package . M Seats . Heated Seats . Clutch Stop . Stubby
2008 Yamaha Raven R6 . FE Kit . Flush Mount Signals . GPR v4
2008 Nissan Titan XE . Long Bed . 4x4 . Line-X
2002 NBP Civic Ex Coupe (SOLD!)
Connie is offline   Reply With Quote
Old 04-03-2003   #4 (permalink)
Connie
Connie's Avatar
That is a great idea! I would get mine powder coated after doing the puddy though.
__________________
Old 04-03-2003   #5 (permalink)
gotti
gotti's Avatar
gotti will become famous soon enough gotti will become famous soon enough
Send a message via AIM to gotti
Awesome!! Maybe I'll attempt to do this to fix my curbed wheel
Thanks for postin this, big help
__________________
TKE.
gotti is offline   Reply With Quote
Old 04-04-2003   #6 (permalink)
SilverStreakEX
Show me your titties, I'M RICK JAMES BITCH!!!
SilverStreakEX's Avatar
SilverStreakEX is an unknown quantity at this point
Send a message via AIM to SilverStreakEX
sweeeet!!!!! thanx a lot man! i got an old set of rims that i can work on, and if i get it good i could do my new ones too.
SilverStreakEX is offline   Reply With Quote
Old 04-04-2003   #7 (permalink)
dragoon
Post Master General
dragoon's Avatar
I found out that duplicolor wheel paint is excellent for its job. I messed up a couple times on the painting, and this paint comes on so thick that it will cover up tiny mistakes when you put on the next coat. I will post pics of my process soon.
Old 04-04-2003   #8 (permalink)
HCCriminal
an0therpin0y
HCCriminal's Avatar
Send a message via AIM to HCCriminal
Genius ... !! and he bought my old rims .. which were heavily scratched ...!! lol ... thanks for buying me a nitrous kit !!
HCCriminal is offline   Reply With Quote
Old 04-04-2003   #9 (permalink)
dragoon
Post Master General
dragoon's Avatar
the back of the rim painted.. i halfassed it since nobody's gonna see
Old 04-04-2003   #10 (permalink)
dragoon
Post Master General
dragoon's Avatar
here is the damaged rim with bondo filled in the scratches
Old 04-04-2003   #11 (permalink)
dragoon
Post Master General
dragoon's Avatar
starting to paint the front
Old 04-04-2003   #12 (permalink)
dragoon
Post Master General
dragoon's Avatar
here's a bit of damage still showing, but you should've saw how it was before. martin aka hccriminal can vouch
Old 04-04-2003   #13 (permalink)
dragoon
Post Master General
dragoon's Avatar
basically the end result. not bad for 25 bucks eh?
Old 04-04-2003   #14 (permalink)
dragoon
Post Master General
dragoon's Avatar
closeup with the glossiness
Old 04-05-2003   #15 (permalink)
HCCriminal
an0therpin0y
HCCriminal's Avatar
so fresh and sooo clean .... !! and yes i can vouch for them ....!! now i wanna see them on the car .. !! please post pics !!
Old 04-05-2003   #16 (permalink)
murd0c
Diamond Member
murd0c's Avatar
murd0c is an unknown quantity at this point
Send a message via ICQ to murd0c
now thats a good DIY how does it hold tho? does it stay on or flake off?
murd0c is offline   Reply With Quote
Old 04-05-2003   #17 (permalink)
Civicly02
Platinum Member
Civicly02's Avatar
Civicly02 will become famous soon enough Civicly02 will become famous soon enough
Send a message via AIM to Civicly02 Send a message via Yahoo to Civicly02
this should be made a sticky because I think a lot of people will benefit from this post
Civicly02 is offline   Reply With Quote
Old 04-05-2003   #18 (permalink)
gotti
gotti's Avatar
Yeah this should be a sticky. Great DIY.
Anyway, does Duplicolor make black opal? Thats the color I have...I kinda doubt they have it
__________________
TKE.
Old 04-05-2003   #19 (permalink)
CivicVTec
Ultimate Member
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
Send a message via ICQ to CivicVTec Send a message via AIM to CivicVTec
nice, that's what i need
CivicVTec is offline   Reply With Quote
Old 04-07-2003   #20 (permalink)
2k2civicRAY
Diamond Member
2k2civicRAY's Avatar
2k2civicRAY is an unknown quantity at this point
Send a message via AIM to 2k2civicRAY Send a message via Yahoo to 2k2civicRAY
make this a sticky! i recently bent a rim and i had to get that part rewelded. me and my dad went back and sanded that part down and then used the same paint that guy did! you can't even tell there is anything wrong now. Doing this saved me over a hundred bucks.
2k2civicRAY is offline   Reply With Quote
Old 04-07-2003   #21 (permalink)
HCCriminal
an0therpin0y
HCCriminal's Avatar
yes .. make this sticky .... !!
Old 04-09-2003   #22 (permalink)
SilverStreakEX
awesome diy dude, awesome diy!
Old 06-22-2003   #23 (permalink)
dragoon
Post Master General
dragoon's Avatar
I never did post a pic of them on my car in this thread. Check my members ride or sig.
__________________
2004 Berlina Black Honda S2000 Hardtopped
SOLD 2002 Turbo EM2
Old 06-27-2003   #24 (permalink)
Silversleeper
Platinum Member
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Send a message via ICQ to Silversleeper Send a message via AIM to Silversleeper
so does the paint come off easily? how strong is it?
Silversleeper is offline   Reply With Quote
Tags
bondo , curbage , diy , fix , fixing , remove , repair , repairing , rim , wheel , wheels
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Falken Ziex Ze-912's or Kumho Ecsta ASX?
Online Wheel Stores & Manufacturers
Black Rims, Red Lip
DIY: Brake Pads and Rotor Install *Updated*
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
