Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 03-06-2003   #1 (permalink)
money9
Super Member
money9's Avatar
money9 is an unknown quantity at this point
Wheel Offset Explanation????
Can someone please help me. I am looking for a set of rims, I am looking to buy a set of 18's (undetermined style) and I am unclear what the offsets mean. Can someone please give me a little more background information on how the offset works or what is refers to PLEASE?
money9 is offline   Reply With Quote
Sponsored Links
Old 03-06-2003   #2 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
From my Rim tutorial at the top of the page....
Quote:
Quote
[hr]The offset on the rims I want is different than stock, will it work?
It depends. If there is not enough offset, you'll have trouble with the brakes fitting in. There are also some rims with very wide lips that are intended for RWD cars that may not work. The offset is the distance (in mm) from the centerline of the rim to the mounting face on the rim. Positive offsets will bring the wheel further into the fenderwell, Negative will push them out. Anything in the 39-44 range should work no problem, but it also depends on how wide the new rim is. Remember that the offset of the new rim is relative to that rim, NOT the stock one. Assuming positive offsets (you shouldn't use negatives, the car will be bowlegged): If the new wheel has less offset (lower number), add the offset difference to 1/2 the difference in width between the 2 rims. If the new wheel has more offset, subtract the offset difference. Less than stock will push the rim further out, more than stock will pull it in.
[hr]
Boilermaker1 is offline   Reply With Quote
Old 03-06-2003   #3 (permalink)
666
Platinum Member
666's Avatar
666 is an unknown quantity at this point
Well said.
666 is offline   Reply With Quote
Tags
06 , 2007 , car , civic , explaination , explanation , explenation , honda , offset , rim , specs , stock , wheel , wheels , works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Falken Ziex Ze-912's or Kumho Ecsta ASX?
Drums--->Discs SPELLED OUT
Black Rims, Red Lip
Online Wheel Stores & Manufacturers
DIY: Brake Pads and Rotor Install *Updated*
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
