| Acceleration wise, smaller tires will give you shorter final gearing (they don't effect the gears inside the tranny) and faster acceleration.
Top end... Larger than stock diameters will give you higher top speeds, but slower acceleration.
In theory, within a rim size there is such a small difference in inertia (since the mass is basically the same distance from the hub) that it can be neglected. Now if you're comparing 14's to 18's, yes... you will probably notice a difference in starts. Once the wheels are rolling at a good clip... it won't make too much difference. |
