Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-25-2007   #91 (permalink)
edicivic2k1
edicivic2k1's Avatar
edicivic2k1 is an unknown quantity at this point
Re: DIY: Brake Pads and Rotor Install *Updated*
Quote:
Originally Posted by Sara-Lee View Post
Grey, thanks for the best guide I've seen on the net.
Grey, ditto. I just reread some of your DIY's for reference, I am preparing to do my timing belt! You definitely have a good eye for detail.
On my Civic, the rear pistons are threaded. You have to screw them in, not push them in using a c-clamp.
You also have to unclip the handbrake cable before you can remove the caliper. The length and position of the brake fluid pipe also makes it impossible to use the trick of unfastening the bottom nut and flipping the caliper up. Instead you have to wiggle and push to lift the caliper off.
I found that my Civic had non-standard pads: that is, they didn't match the model and year chart at Halfords, or online. I guess this isn't usual. But before buying pads, I wished I had taken them out and drawn the profile and measured. That would have saved a lot of time.
Uh, Feminazi Sara-Lee, may I suggest, and this is just a suggestion, that you leave the year, and model of your vehicle so that you can add intelligence to this thread? There may be others in the same [let's hope not, but, I guess it is possible] predicament as you.
Then a couple of other notes. First for the admin: I thought this stuff was worth leaving as a note, but I really had to struggle to register. The registration form seemed to be adding in blanks and line breaks in the email sent out. It might just be me, but...
Uh, Feminazi Sara-Lee, if you are struggling to register to this website, you may want to board the short bus tomorrow morning.
And lastly, to add a bit of petrol to a fire... Manutd0018 and and dru016, what kind of twats are you to use pictures like that? Are you maybe 13 years old, not 18 and 16 like your names suggest? Girls drive and mod Civics too.
Uhhhh, Fem-i-Nazi, Sara-Lee, for the most part, folks on this website are from the U S and A. Here, we have privileges that allow us to make choices on our own. Just like your unfortunate choice to leave a comment here on this forum!!
No need to reply. This is a one time posting. And, no I'm not a lesbian, and yes, I do get quite a lot.
Feminazi Sara-Lee, are you sure about this? Have you discussed this with anyone?
Thanks again Grey for the brilliant howto,
Sara-Lee
Feminazi, this is the only comment you made that raised our trust in your intelligence. Sorry Hunny, [if you are a chick.]
Bye.
Oh, and Feminazi? No need to reply. This is a one time posting.
edicivic2k1 is offline   Reply With Quote
Sponsored Links
Old 11-18-2007   #92 (permalink)
eruffini
New Member
eruffini's Avatar
eruffini is an unknown quantity at this point
Send a message via AIM to eruffini Send a message via MSN to eruffini
What would be a disadvantage to NOT greasing the back of the brake pads?
eruffini is offline   Reply With Quote
Old 11-18-2007   #93 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Quote:
its not a dis-advantage to not put it on the back but an an advantage to put it on the back as it MAY reduce brake noise
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 11-18-2007   #94 (permalink)
eruffini
New Member
eruffini's Avatar
Quote:
Thanks!
Old 07-22-2008   #95 (permalink)
Dash555
New Member
Dash555 is an unknown quantity at this point
Has anyone else noticed a slight vibration coming from the brake pedal during moderate braking after installing cross-drilled rotors??
Dash555 is offline   Reply With Quote
Old 07-22-2008   #96 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
Quote:
If you have a vibration after new rotors its not from them being slotted. Its from not indexing the rotor to the hub to minimize run-out. Max run-out is .003" (.004" per honda ) and the best way to cure the problem now is to have them machined on the car!
__________________
Or
DIY Head gasket
Old 09-01-2008   #97 (permalink)
DarkFlame
New Member
DarkFlame is an unknown quantity at this point
Grey, great DIY. I've done brake rotor/pad replacements on most of my vehicles, & your DIY seems spot-on. But I do have a couple of questions:
1-) I never know the difference between "right-hand" & "left-hand" threads. "Standard" threads are clockwise to tighten & counter-clockwise to loosen (as my wife says: "Righty-tighty & Lefty-loosey"). But which way to tighten/loosen "right" or "left" hand threads?
2-)We have always bled brake lines by attaching a piece of rubber hose to each bleeder nipple an pushing the other ends into clean soda bottles half-full of fresh brake fluid, then bleeding the brakes individually, starting with the one furthest from the master cylinder (longest line) & ending with the one closest to the master cyl (shortest line). this allows a single person to bleed the lines - w/o help. of course, one must always be careful to not let the master cyl run dry. however, it has always worked for me, and I've never needed any help bleeding the lines. Is there a problem with this method?
3-) & here's why I'm wanting to UPGRADE the brakes & not just "replace" the pads & rotors on my Civic ('98 LX w/90k "all mine" miles): the rotors always seem to warp before the pads get halfway worn out! (and, I want to drive the thing another 10 years or so w/o having to replace the rotors several more times. SO, what would be the best heavy-duty rotors available?
Please excuse any typos - I'm typing this on my PocketPC from the hotel room (kids & wife are asleep) while we're out of town, and my fingers are fatter than these keys!!!
Thanks for sharing your expertise,
David
San Antonio, TX
DarkFlame is offline   Reply With Quote
Old 12-08-2008   #98 (permalink)
00telehit
New Member
00telehit is an unknown quantity at this point
I have ROTORA BIG brAKE KIT ON MY CIVIC, THEY ARE AWSOME WAY BETTER THAN BREMBO, BUT IF U WANT BETTER THAN ROTORA, U CAN GO WITH WILLWOOD BRAKE SYSTEM, OR ENDLESS .........THEY ARE GREAT, BUT U GONNA NEED A TON OF CASH.
NOTE: this pics are from my old civic, this same rotora brake system it ll be install in my new EM2, i have a bunch of after market parts sitting in my garage, but im waiting for the winter to be over, so by spring i ll put the big brake kit, and the other stuff, i need this EM2, really clean jdm style, for the beginning tour of HIN in april.
and to explain thing better, as u see in this 2000 civic ferio, it has a set of advan wheels, those wheel are now on my EM2, here is a pic.
Last edited by 00telehit; 12-08-2008 at 10:35 AM. Reason: because i need to add something else , that i forgot
00telehit is offline   Reply With Quote
Old 12-08-2008   #99 (permalink)
sl33pyriceboi
Ultimate Member
sl33pyriceboi's Avatar
sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold sl33pyriceboi is a splendid one to behold
Send a message via AIM to sl33pyriceboi
^ur car looks ridiculous... drop that poor thing
__________________
7thGen.MT.C.
Quote:
Originally Posted by gearbox View Post
alot of people just talk to say something. most of the time they have no idea wtf is going on lol
Quote:
Originally Posted by manahoonie View Post
lol. well we got newbs to use the SEARCH button.... NOW the next step is to look at the date
Step 1) SEARCH
Step 2) DATE CHECK
sl33pyriceboi is offline   Reply With Quote
Old 12-08-2008   #100 (permalink)
supafil25
Senior Member
supafil25's Avatar
supafil25 will become famous soon enough
going back to the first post
if you dont know how to do brakes you shouldnt work on a car.
supafil25 is offline   Reply With Quote
Old 09-07-2009   #101 (permalink)
02Hondadx
New Member
2002 Honda Civic
02Hondadx is an unknown quantity at this point
Quote:
Originally Posted by streetglower View Post
So basically before I bleed the brakes I take out as much fluid from the resovoir and then put new fluid in there. Then I start with one brake and bleed it and then add more fluid when it gets low. Then I do this 3 more times, then fill it again at the end. So I need to fill it after bleeding each brake.
Just don's drain all the fluid out, other wise you will have a bunch of air in the lines and that is not good.
__________________
1SloCrew
Fredericksburg, VA
02Hondadx is offline   Reply With Quote
Old 09-07-2009   #102 (permalink)
02Hondadx
New Member
2002 Honda Civic
True, but you have to know how to do it eventually. I know how but, there are some people that are new to the whole working on your own car thing.
__________________
1SloCrew
Fredericksburg, VA
Tags
2002 , 2003 , 2004 , 2006 , brake , chance , civic , diy , forum , honda , install , installation , pad , pads , rotor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
