Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-06-2005   #61 (permalink)
Shlomo
Super Member
Shlomo's Avatar
Shlomo is an unknown quantity at this point
Send a message via AIM to Shlomo
well i just finished changing the rotors and pads (brembro blanks...pbr/axxis ultimates) and things went pretty smoothly once we started using air tools. i weighed the stock rotors and they weighed the same as the brembros, 11.5 lbs each. so no weight reduction there in case anyone was still wondering. tommorow i will hopefully change the fluid and take my car out for a spin. To remove this ad, register today for free or log in if already registered!
__________________
02 SSM EM2
check out my band *The Awesomes* @ http://www.theawesomes.vze.com
Shlomo is offline   Reply With Quote
Sponsored Links
Old 04-03-2005   #62 (permalink)
orion_squall
Diamond Member
orion_squall is just really nice orion_squall is just really nice orion_squall is just really nice orion_squall is just really nice orion_squall is just really nice
Can I still use this DIY for if I got ABS?
orion_squall is offline   Reply With Quote
Old 04-04-2005   #63 (permalink)
Shlomo
Super Member
Shlomo's Avatar
i've got abs and had no problems at all.
__________________
02 SSM EM2
Old 05-29-2005   #64 (permalink)
eightone
New Member
eightone is an unknown quantity at this point
hi just had a question, so is there no need to mess with the spindle nut in the center?
eightone is offline   Reply With Quote
Old 05-29-2005   #65 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
Quote:
no there is no need to mess with that nut unless you are installing new axles, removing the spindle or any other things under the rotor.
__________________
Quote:
Originally Posted by AggressiveAdam
hah yes the K series will make your car fly.
Quote:
Originally Posted by McFLYsi View Post
just got pulled over the other day for having JDM yellow headlights, the cop told me it was illegal to have yellow lights, only white, any comments on this. i was just sittin in my slab with trunk poppin and my candy paint drippin off my doors.
streetglower is offline   Reply With Quote
Old 05-29-2005   #66 (permalink)
Shlomo
Super Member
Shlomo's Avatar
^^yup
__________________
02 SSM EM2
Old 05-30-2005   #67 (permalink)
winnerpl
Senior Member
winnerpl's Avatar
winnerpl is an unknown quantity at this point
What's a good place to get good brakes?
winnerpl is offline   Reply With Quote
Old 09-14-2005   #68 (permalink)
knipple
New Member
knipple is an unknown quantity at this point
Send a message via AIM to knipple
For those that have a Torque Wrench, the torque specifications for the two inner bolts(the ones that when removed allow the caliper to be removed from the wheel) is 79.6 ft lbs.
knipple is offline   Reply With Quote
Old 09-18-2005   #69 (permalink)
Nates02EX
Senior Member
Nates02EX's Avatar
Nates02EX is an unknown quantity at this point
Hey I did my brakes today and one of those damn screws stripped so i had to drill it out, just incase anyone wants to know, the size of these screws are M6, i went ahead and bought a few incase i did it again next time.
Nathan
__________________
'02 EX Sedan, NHBP, Eibach Sportlines, 17" Momo RPM 215/45/17 BFG's
7th gen blacked out crew member #7
Nates02EX is offline   Reply With Quote
Old 10-01-2005   #70 (permalink)
def01tones
You bought a used dog??
def01tones's Avatar
def01tones will become famous soon enough
Send a message via AIM to def01tones Send a message via Yahoo to def01tones
i will be attempting this DIY here in a few mins. im alittle nervous about running into probs and not knowing what to do. so everybody pray for a fellow 7thgen member to pull through this with flying colors. also do i absolutely need to bleed the brakes??? cuz that sounds kinda complicated for all 4 brakes since i will be alone.
__________________
Quote:
Originally Posted by SEN_ONE
I wish I could get my girlfriend from a four finger to a two finger gap.
def01tones is offline   Reply With Quote
Old 10-01-2005   #71 (permalink)
Skunk2ner
Diamond Member
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
Quote:
i didn't bleed the brakes when i did it. the whole process is pretty easy, but i highly highly suggest getting an impact screw driver if you don't have one. it took me 15 minutes to do one side when i had the impact screwdriver and it took me hours to do it without it.
Skunk2ner is offline   Reply With Quote
Old 10-01-2005   #72 (permalink)
streetglower
7thGen Junkie
If you are alone, and dont have a 1 person brake bleeder kit, then you cant do it. You dont have to bleed the brakes if you dont open the system up, but it would be a good idea to go ahead and have it done if you have fluid that has been in there for along time. Overtime, the boiling point of the fluid will decrease and more moisture will build up in the fluid and cause problems. Also dirty fluid can cause parts to wear out faster. Its pretty easy to do as I bleed my friends brakes with another person for the first time several weeks ago on his wifes car.
__________________
Old 10-01-2005   #73 (permalink)
def01tones
def01tones's Avatar
^^^alright i feel alittle better after that. ill bleed them another time then.
__________________
Old 12-12-2005   #74 (permalink)
01civicexboy
Member
01civicexboy is an unknown quantity at this point
I will be replacing my brakes this weekend and do I absolutley need this impact screw driver? Can I do it with a normal driver or is it going to be tightened too much?
__________________
2001 Civic EX Coupe Auto
Arospeed Express 17's
205/40/17
Custom Interior trim painting
SYSTEM:
Pioneer Headunit
Phoenix Gold wiring with Fosgate 800 watt amp pushing ///\lpine Type S 12
WTB: Passenger and driver sides headlights..MUST BE OEM!
01civicexboy is offline   Reply With Quote
Old 12-13-2005   #75 (permalink)
streetglower
7thGen Junkie
it may be tight, it may not be. you have to pull the tires off and check. Mine werent, but yours may be.
__________________
Tags
2002 , 2003 , 2004 , 2006 , brake , chance , civic , diy , forum , honda , install , installation , pad , pads , rotor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
