What's considered "lite"?
Old 06-29-2002
BigL's Avatar
BigL is an unknown quantity at this point
I've got a set of Konig Toxxins 17" and they weigh in at just over 17 lbs each. Is that considered lite?
Old 06-29-2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
17 lbs humm wow that is lite mine I am looking at RS6 are like 20 lbs each so they would be lighter than mine.
Nick
Old 06-29-2002
Mbow's Avatar
Light for a 17" would be in the 12-15lb range. Although, 17lbs isn't all that bad. Plenty of members have rims that weigh much more than that. Imo, you really want a rim/tire combo that is light as possible. However, to get a really light combo, you may sacrifice handling. Anyhow, I'd say anything that weighs the same or less than the stock setup is good.
Old 06-29-2002
dragoon's Avatar
i'd say 17lbs is quite good. motegi mr7's (very popular with members on this site) weigh in at around 24
Old 06-29-2002
BlackSI's Avatar
BlackSI is an unknown quantity at this point
for 17's thats pretty lite, there are some that are lighter, but the lighter u get the worse the selection. I'[IMG]i/expressions/beer_yum.gif[/IMG]
Old 06-29-2002
aferenz's Avatar
aferenz is an unknown quantity at this point
Ok I just looked it up but couldn't find my exact answer. What is our stock wheel weight? The chart I was linked to from this site had a civic EX 92+, which had 14's and they said 18lbs. Well I have an EX, I want a pair of 17's close to the stock weight, is that possible?
Old 06-29-2002
I was hearing 21 lbs or so? But I am not for sure or 23 lbs
Nick
Old 06-29-2002
Mbow's Avatar
I have a fairly decent scale at home. I weighed my 15" steel rim with the cap and got 21lbs. That was weighing myself and then getting back on the scale with the rim and cap. I am not saying that I have the most accurate scale in the world but it should weigh around +/- 21lbs.
Old 06-29-2002
BigL's Avatar
"...the lighter u get the worse the selection..." Thats not necessarily true. The Toxxins are lite and they look pretty good. The handling is not that bad either.
Don't you guys think the Toxxins look pretty good for a lighter rim?
I hope you guys don't get mad for using pics of your rides.
Old 06-30-2002
Mbow's Avatar
Ummm....toxxins weight 18.6lbs in 17". You would be several pounds over the weight of the stock setup. Not good..
I think people need to remember that when you increase your rim/tire weight over stock, you are loosing acceleration performance. Some members have posted reductions in 1/4 mile times of .5 secs when they took their bling, bling, wheels off and put the stock steelies back on. Anyhow, it all depends on what you want.
Old 06-30-2002
9K Redline Owns U
Spider883's Avatar
my 18" konig toxxins only wiegh like 19-20lbs. but that doesnt include the tire
Old 06-30-2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
17 lbs is medium range on weight. Racing wheels are usually under 12 lbs. For street or street/strip 12 to 15. The move from 17 lbs down get expensive. So, it depends on what your trying to accomplish vs. the money involved. Stock steelie weighs 24 lbs.
Old 06-30-2002
Thanks familyman for clerifying the 24 lbs on those hubs.
Nick
Old 06-30-2002
BlackSI's Avatar
The OZ superleggeras are 15.8lbs in the 17inch size from what I heard.
Old 06-30-2002
Mbow's Avatar
Quote
[hr]Originally posted by: FamilyMan
17 lbs is medium range on weight. Racing wheels are usually under 12 lbs. For street or street/strip 12 to 15. The move from 17 lbs down get expensive. So, it depends on what your trying to accomplish vs. the money involved. Stock steelie weighs 24 lbs.[hr]
Where are you getting 24lbs from. Do you weigh them or what?
Old 06-30-2002
aferenz's Avatar
So it's possible to get a cool looking set of 17's that improve performance? I think small rims don't look good, but I don't want less power or MPG.
Old 06-30-2002
Mbow's Avatar
Well, there is more to it than just weight. It's not just the weight in itself, but also where the weight is around the wheel. IE, Like is all the weight on the outside of the rim, on the inside near the hub, or evenly distributed. Plus, a small increase or decrease in overall tire diameter will affect acceleration as well. In order to get 17s and stay below the stock weight, you would have to go forged and then you are talking around 300 per rim. 16s would be the best of both worlds on the street imo. 17s are basically going more to the looks side and 15s are going more to the acceleration side. 16s you can get pretty light and still get the same handling as the 17s would provide. Just get a 16x7 or 16x7.5 rim.
I have 15s subs and my combo weighs 31lbs per wheel/tire. If you go above 40lbs per wheel/tire, then you are basically taking away some if not all of any gain you have received from your performance parts.
Light weight wheel/tire combo is probably the best mod that you can do to improve the acceleration on our cars right now. Also, since you are reducing your sprung weight, your suspension will work better and have a much easier time keeping the wheels planted to the road.
Oh, one last thing to remember, even if you get light weight 17" rims, you are still putting a big heavy 17" tire on it. All in all, if you really don't care too much, just get the rims that you like and put them on. I know my little 15" subs improved my acceleration big time, but I gotta say, they look like sheite.
Old 07-01-2002
DIY King
Grey's Avatar
The best bang for the buck nowadays are the Rota Attack in 17" format from www.revolutionsmotorsports.com for $522.50!!! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old 07-01-2002
BlackSI's Avatar
17's prety much slow ya down, but if you get some light ones probably wont notice it, but if you go with lite wheels lke superleggera 15inchers about 11lbs with some light tires it will help a little on acceleration and handling. Remember tires are even more important as far as weight goes cause they are the furthest from the center of the rotating inertia. The lightest tires will cost more, but if u want to get every ounce of performance then get light 15 inchers or even 14's, but if you want overall better handling and looks then go for the 17's
Old 07-01-2002
DIY King
Grey's Avatar
Did I mention that the Rota Attacks weigh 15.5lbs? Nice huh? Me like!!! [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old 07-01-2002
aferenz's Avatar
Thanks big time for the info guys. I want looks over performance, I mean I don't race. On the other hand though I don't to make things too much worse on the performance side. 16's sound good for that purpose, but damm 17's look so much nicer, I guess I got some thinking to do. Damm thinking hurts my brain.
Old 07-01-2002
BlackSI's Avatar
Yup, in general I say whatever little you lose by getting 17's (unless they're like heavy A** wheels) you gain in looks and handling. 17's will aways rule (in looks and handling) over 15's or 16's
Old 07-01-2002
BigL's Avatar
If you really want to go for looks and couldn't care less about performance then why not get 19"s?
Anyone got any pics of 19"s on a civic?
Old 07-01-2002
Mbow's Avatar
Quote
[hr]Originally posted by: BlackSI
Yup, in general I say whatever little you lose by getting 17's (unless they're like heavy A** wheels) you gain in looks and handling. 17's will aways rule (in looks and handling) over 15's or 16's [hr]
17s will rule in looks over a 16 but not handling.
Old 07-02-2002
19" and a chick
Old 07-02-2002
RevHigh's Avatar
RevHigh is an unknown quantity at this point
When I was shopping for rims, my rule was to stay under 20 lbs so they wouldn't be too porky. Plus I didn't have the money for Racing Harts. What did I go with? 17" Konig Tantrums - 19.2 lbs. Still a few pounds over stock, but come on, our cars are slow anyway [IMG]i/expressions/laugh2.gif[/IMG]
Old 07-02-2002
vtechin's Avatar
vtechin is an unknown quantity at this point
Mine wiegh in at 18 lbs each with out the tire. By the way Yokohama tires suck. They are so dam loud.
Old 07-02-2002
Edens's Avatar
Edens is an unknown quantity at this point
My 17x7.5 SSR competition weigh in at 11.9 lbs
raymondxcho
09-29-2015 09:00 PM
speedlever
09-24-2015 07:18 PM
Klame9420
09-18-2015 12:37 PM
Quick Reply: What's considered "lite"?
