Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen > Wheels, Tires & Brakes
Register Forgot Password?
Wheels, Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 06-24-2002   #1 (permalink)
Rev
Rev is an unknown quantity at this point
Wheel Alignment Question
Hi!
I recently had wheel alignment done on my 2001 Honda Civic, and since I
don't know much about wheel alignments, I thought I would ask a question
or two on this forum.
The scoop is this: a few month after I bought the car, the steering became
sloppy. Going in a straight line at highway speeds, the car would drift
slightly left and right, especially when there was wind or small bumps in
the road. The steering wheel felt stiffer, too, and less precise.
I often check tire pressure so I could rule out that possibility. The
dealerships claimed that all steering components were ok. So, just last
week, I decided to check wheel alignment (under warranty, since I am still
under 12k).
Here is the before and after printout I got from them.
The format of all lines is:
ACTUAL, BEFORE, [SPECIFIED RANGE], in degrees.
2001 Honda Civic
Front left tire
Camber: -0.3 , -0.3, [-0.8, 0.8]
Caster: 1.2, 1.2, [0.6, 2.6]
Toe: 0.02 (again, everything is in degrees), -0.02, [-0.12, 0.12]
SAI: 14,1, 14.1 []
Front right tire
Camber: -0.9, -0.8, [-0.8, 0.8]
Caster: 1.5, 1.5, [0.6-2.6]
Toe: -0.01, -0.05, [-0.12, 0.12]
SAI: 15.0, 14.9 []
Rear left tire
Camber: -0.3, -0.4 [-1.5, 0.0]
Toe: 0.10, 0.11, [0.04, 0.16]
Rear right tire
Camber: -1.2, -1.1, [-1.5, 0.0]
Toe: 0.06, 0.00, [0.04, 0.16]
The alignment helped, but not too much. There is still a lack of stability
at highway speeds. In addition, the steering wheel is now off-center by
about 1/3 of an inch (which I heard was a common problem with alignments).
I'd like to go to another dealer and do yet another alignment, but I would
like to be prepared this time. The questions are:
1) Regarding the alignment above, did the dealer do a good job? Do I need
another alignment? What would be a good alignment for better straight-line
stability, without increasing wear on the tires too much?
2) Should I be worried about the right camber being out of spec (-0.9
degree vs. the allowable -0.8 degree)? I know camber is not adjustable in
these cars (but can be fixed by replacing parts). I have been extremely
careful with the Civic and have not hit anything to cause the camber to
change. The car hasn't been involved in any accidents. Should I ask the
dealer to try to fix it, or is it not a big deal?
3) If I need another alignment, can you recommend a dealer in the San Jose, CA
area?
Many thanks in advance!
Andrew
Rev is offline   Reply With Quote
Old 06-27-2002   #2 (permalink)
vtecharry is an unknown quantity at this point
Your alignment settings were fine to begin with and all were within factory specs (allowed ranges).
This shop that did the wheel alignment didn't align anything.
If you notice, all your "after/actual" specs are only .01 or .02 different. All they did was lean on a couple of tires or take the readings again so it recorded slightly different settings that was it.
The problem with stability which I 've noticed in my '01 Civic EX coupe is the SHOCKS! They suck and they deteriorate fast. I noticed the TOE went to 0 on one tire in the back. Tell them you want the other tire set to 0.0 as well. 0 toe in the back helps with stability (don't worry about the range, those toe ranges will ruin your tires faster and make the car more unstable). Have them set the rear left tire to 0 as well, but the biggest factor in stability is shocks and springs. Our shocks are for the dogs. Honda really screwed up with those. I think I 'll be left with no alternatives but to spend the $500 on the Konis plus labor, plus $150 for springs, probably $1,000 after all is said and done and it SUCKS! My '97 Civic had 140k mi. when I sold it and it solid on the highway with the orgininal shocks & springs. The '01+ suspension just plain sucks.
vtecharry is offline   Reply With Quote
Old 06-28-2002   #3 (permalink)
Royando's Avatar
Royando is an unknown quantity at this point
Send a message via AIM to Royando
I agreee...my camber in the rear of my 01 civic is off..and i can totaly see that my wheels are leaning a little to the inside...what is up with that???!!!!hehe
Royando is offline   Reply With Quote
Old 06-28-2002
CivicForums
Honda Civic
Paid Advertisement
Tags
2001 , 2002 , 2003 , 2007 , alignment , camber , castor , civic , civics , cost , honda , in , problems , specs , toe , wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Falken Ziex Ze-912's or Kumho Ecsta ASX?
Black Rims, Red Lip
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
DIY: Brake Pads and Rotor Install *Updated*
BIG ASS RIMS ON THIS CAR---->
Wheels, Tires and Brakes FAQ
Suggestion for 19" Chrome Rims
Contact Us - Honda Civic Forums - Honda Civic News - Archive - Top
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Emails Backup
