can I run a bigger tire than 195/60/15?
Old 09-20-2016
bhollie's Avatar
bhollie is an unknown quantity at this point
hey guys, this car rides rough! suspension is fine.. ive had another one of these 2001 EX coupes and it did them same thing.. my question is how big can i go to get a smoother ride on the stock steel rims?
thanks
Old 09-26-2016
bhollie's Avatar
Re: can I run a bigger tire than 195/60/15?
anyone please?
Old 09-26-2016
Prelude Owner
GolNat's Avatar
Sure you can go bigger but your speedo will be off. Not sure how big, maybe a local tire shop can get you the specifics based on a particular tire.
Honestly I don't think it will help much as a 60 series is a pretty tall tire. Civic's ride a little on the rougher side especially the 7th gen. It's worth a try if you need new tires anyway, it might just ease it enough for you to be ok with it.
Old 09-27-2016
bhollie's Avatar
thanks for the reply i appreciate your time..
Old 10-03-2016
GOT SAND?
Dooner's Avatar
Dooner is an unknown quantity at this point
If you go to Discount Tires website, they have a "tire calculator" link under the "info center" link. Plug in your current size, then the size of the tire you may want to run. It will tell you the differences in sizes between the two sizes you input. Play around with it.
Old 10-04-2016
Mad Dog Tannen's Avatar
I would run 14's with a taller tire (same overall diameter). It will give you a little more sidewall. Then you can look at sidewall flex ratings for the tires and find a softer tire.
Old 12-09-2016
RoseyEm2's Avatar
RoseyEm2 is an unknown quantity at this point
Depends on how low you are because I dropped my car 2in all around and I just got 195/65/15 and they're pretty big. I recommend it.
Old 01-25-2017
Pier7866's Avatar
Pier7866 is an unknown quantity at this point
thanks
Well your complete wheel diameter should remain the same like I had 15" alloy wheel Honda oem with 195 60 R15 I bought 16" Honda HFP alloys with 205 50R 16 so if your rim goes larger your tire will become low profile to some extend to keep the diameter of the wheel same. Hope this help
Old 01-31-2017
GOT SAND?
Dooner's Avatar
OP: Any updates for us?
Jomodeere
06-09-2016 09:17 PM
fellnerkat
05-10-2016 01:06 PM
Suchsloth
04-19-2016 07:54 PM
tyler8469
03-15-2016 09:25 AM
onelifetolive
Bolt-on Engine Performance
11-10-2001 10:58 AM
Quick Reply: can I run a bigger tire than 195/60/15?
