03 civic ex e brake loose
Rep Power: 0 03 civic ex e brake loose
i have a 2003 honda civic ex 5 speed. i was wondering if there is a way to tighten up the e brake so its harder also the handle is loose too meaning there is ALOT of play before it starts to engage. thanks.
Rep Power: 210 Re: 03 civic ex e brake loose
Jack up the rear end and put it on stands. Open up the rear of the center console . Now, spin a rear wheel and tighten the bolt on the e-brake cable inside the console until it just catches and stops the wheel. Then back it off just a bit. Put the console back together, drop the rear end and you're done.
thesushiboy
04-12-2015 02:54 AM
