Honda Brake Fluid or any dot3?
Rep Power: 0 Honda Brake Fluid or any dot3?
Honda civic 2001 LX, manual says I should use Honda genuine brake fluid. Can I use any dot3 brake fluid or does it have to be honda brake fluid?
1 Post
Rep Power: 328 Re: Honda Brake Fluid or any dot3?
Dot3 or dot4 is just a rating the higher the number the better it is.
So if u can, get dot4. It has a higher wet/dry booing point. Dot4 is also backward compatible
1 Post
DOT4 standard has a higher wet/dry boiling points...means it can take more heat before the fluid boils (and when it boils, it becomes no good and ur braking system goes to ****)
most fluid now a days are are DOT4 unless u buy some no name cheapy chit.
you will normally see DOT3 on a DOT4 bottle (it'll say "DOT3/DOT4") because its the same great fluid, but better.
so as far as stopping distance, if ur brake fluid gives out, then u wont be able to brake...hows that? it will normally give out in higher stress situations like if u are on the track, canyons, hauling a heavy load (and using brakes)...etc
Received 1,440 Likes
Rep Power: 338 Re: Honda Brake Fluid or any dot3?
if you drive normally, and don't have any long downhill, just go dot3 if price is different.
also, many guys "think" they drive hard. speeding is not driving hard.
Autocross Padawan
Rep Power: 186 Re: Honda Brake Fluid or any dot3?
ATE super blue... problem solved
It's in German.. so you KNOW it's good!
...no seriously, it's fantastic brake fluid. Best DOT4 fluid you can buy. I went through 2 seasons of autocross and the brakes were consistently firm. Fluid is only slightly discolored after all that use.
Live for the Twisties
Rep Power: 260 Re: Honda Brake Fluid or any dot3?
Just a friendly reminder to everyone, once you open a bottle of brake fluid use it all, once open it's not shelf stable and it could damage your braking systems if used at a later date.
Also, brake fluid eats paint, so don't get any on your body panels.
1 Post
correct. one of the properties of brake fluid is that it absorbs moisture. so if u leave it out long enough and it absorbs enough moisture.... u dont want to be putting that in ur brake system.
Rep Power: 787 Re: Honda Brake Fluid or any dot3?
i wasnt impressed with oem. after 3 yrs there were large chunks of fluff and other junk in the bottom of the master cylinder. i sucked them out with a small turkey baster before having the fluid flushed. and i dont think there should be any considering honda recommends 3 yrs for a fluid change. valvoline makes an excellent fluid from what i hear. i am very easy on brakes, almost never use em above 35mph, and they usually do not even get hot enough to reach normal operating temp.
The Boss ;D
Rep Power: 0 Re: Honda Brake Fluid or any dot3?
^Warranty voider
1 Post
Rep Power: 198 Re: Honda Brake Fluid or any dot3?
geez... I just realized my front brake pads lasted 55k... still stock rotors and stock rear drums/shoes...
1 Post
especially if it is a DD...even if heavy braking/traffic.
but like like oil, brake fluid has come so far...so that dot4 is just as cheap as dot3..so there is no real point in getting "dot3" cuz 90% of the fluid out there is dot4 anyways (which has a higher wet/dry boiling poit than dot3)
you can get a 1L of valvoline dot4 at autozone for like $6...which is enough to flush ur whole car completely.
It's has the same specs. They make it in blue and amber so that when you flush you can switch between the two and tell if the fluid is new or old. Obviously this is for people that take their car to a track and want to make sure the fluid is fresh and change it before any difference is noticeable.
mattdoc
03-14-2017 12:10 PM
jessicakaybby
04-20-2015 12:11 PM
Bartkat
20
02-19-2002 01:29 PM
