View Poll Results: What kind of Rims should I get with the car color being silver?
Chrome
0%
Black
64.29%
Gunmetal
28.57%
Hypersilver
7.14%
Voters: 14. You may not vote on this poll
19 inch rims will they fit?
Rep Power: 0 19 inch rims will they fit?
Guys i just got into a Civic and for now it has 17 inch rims but I was wondering if I could put 19's on it without having to do any mods to it? Any suggestions?
1 Post
Rep Power: 328 Re: 19 inch rims will they fit?
You could but why? Most members on here will tell you 17 is the highest you should go. But each to his own.
And color depends on which rims you get. Some colors will look better on other rims
And no chrome
And no chrome
Live for the Twisties
Rep Power: 260 Re: 19 inch rims will they fit?
Up to 20'' fit on most generations, but anything over 17'' starts to look funny.
Anything above 17'', especially chrome rims, are also starting to get very heavy so they'll hurt performance and fuel economy significantly.
Received 1,440 Likes
Rep Power: 338 Re: 19 inch rims will they fit?
fender gap no more, you will start having body to ground gap - alot
EM2ti
Rep Power: 269 Re: 19 inch rims will they fit?
Running 19x7.5 Forged Traklites with 215/35/19s. 17.5lbs. Dropped 2" on Tein Flex Coilovers, 0857 Raised Steering Bracket, J's Racing Tie Rods and RCAs. Rolled Fenders. -2 degrees front / - 1.5 degrees rear camber. 8+ years with no issues, no rub.
People don't realize that they're 19s until they ask (most common remark is that they look like 17s). I guess the flat black color doesn't make them look so oversized. My gunmetal set are another story. They look huge. I guess color does make difference.
Try to go forged if you can. Cast 19s will push you well into the mid-20lb range. For reference, steelies are about 18 lbs. You think your Civic is slow now... I can still chirp in second gear with the forged, sometimes third.
EM2ti
Stock Height - No Mods Required
When I was running Neuspeed Sports / Tokico D-Specs (About 1.25" Drop) - I had to mildly roll the rear fenders. Started out at -1.5 degrees rear camber. Increasing about - .2 degrees/year, due to sag. I think I was well over -2 degrees with almost a 2" drop. Fronts were never an issue until...
I dropped about 2.25" Front and 1.75" Rear (settled to about 2") w/ front camber at -2 and rear at about -1.5 or so. Had to roll fronts and remove the fender liners.
You are limited to a handful of tire manufacturer choices. Not too many 215/35-19 players out there. A bit pricier too. Straight line performance takes a little hit. More so, with the cast wheels. Zigzags - no compromises. Stiffer sidewalls are plus for handling, but get ready to rattle some teeth. Women always complained about the ride hurting their *****. I got a kick out of it though. Haha.
I enjoy the look, that's why I did it. If that's what you want. Go for it, who cares about everyone else. It's your car, do what makes you happy.
Your front brakes will looks TINY. The rear drums will look even more ridiculous. I swear I could see all the way to China, looking through the wheels from the side profile. However, cleaning the suspension and brakes are a piece of cake, through the spokes
Gas milage does take a bit of a hit. On steelies I averaged about 400-420 miles per tank. With 19s, I averaged about 380-400 (even with relatively light 17.5lbs wheels). After the 12" Wilwood BBK, 350-370 per tank. Inertia, rotational mass and unsprung weight are killers. Typically, you can go one of two routes: Smaller and lighter for speed/efficiency or Bling for the opposite.
With that said, my next purchase will be a set of 16" Regas or SW388s (12 lbs or so). I just found out they'll clear my calipers and rotors. Better MPGs, Cheaper Tires, a couple tenths shaved and some Russian/JDM Eye Candy, to boot. WIN/WIN
I'll still rock the 19s in the summer.
215/35-19...
yeah, with these they will not lift the car up.
good write up
good write up
mods, stick this one to the top
EM2ti
There was another member interested in 19s. I figured you may need some visuals too. I don't have my laptop anymore (saving for a new Mac) so more often than not I post from my phone. Here's a link to some pics from a long time ago. 19" Gunmetals, dropped 1" (before my car settled).
https://www.civicforums.com/forums/4...-my-civic.html
TheRubixHorse
07-29-2015 05:22 AM
jferristx
07-08-2015 10:09 PM
