wheel cylinder sealant?
Old 02-07-2006
streetglower's Avatar
Does anyone know what kind of grease/sealant goes behind the wheel cylinders when installing them?
Old 02-07-2006
anyone?
Old 02-07-2006
Jap-Euro Fusion
Boilermaker1's Avatar
Just checked the manual, no reference of any sort of grease is made. Says soak the parts in DOT3 brake fluid and air dry before installing.
Old 02-07-2006
well on page 19-24 of the manaul it says to use cemedine 366E sealant or equivalent between the wheel cylinder and backing plate. I just want to know whats equivalant to that.
Old 02-07-2006
BLDNPSI Mod
tfnaaf's Avatar
are asking about between the surface between the BACK of the W/C and the backing plate? If so some cars use a sealant similar to silicone, not sure why but ive seen it many times. Not like dirt/contamination wont enter from between the drum and backing plate
Old 02-08-2006
so it is necessary to even use it?
Old 02-08-2006
BLDNPSI Mod
tfnaaf's Avatar
I've never used any at that location ever. And i cant imagine why it would be needed in the first place. I imagine if there was huge gaping holes around the w/c then yes it may not be a bad idea. But i dont believe that is the case
Old 02-08-2006
tacheon's Avatar
tacheon is on a distinguished road
On my previous Dodge, RTV was specified. I believe it's just to keep road grit out.
SimpleUser
04-24-2021 02:54 AM
OptimisticWay
46
10-15-2015 02:16 PM
carid
Wheels and Tires
07-20-2015 07:15 AM
Genyc07
Wheels and Tires
07-11-2015 05:51 PM
Steinar.D
Transmission
07-10-2015 01:38 AM
Quick Reply: wheel cylinder sealant?
