Which tire size would be best for 18 x 7.5 Rims???
Rep Power: 0 Which tire size would be best for 18 x 7.5 Rims???
If I was to buy an 18 x 7.5 wheel which tire should I get?
a) 215/35/18
b) 215/40/18
c) 225/40/18
I'd like to know your ideas based on your experiences. I want good handling. I'm not gonna drop my car.
Thanks
a) 215/35/18
b) 215/40/18
c) 225/40/18
Thanks
Rep Power: 280 do you even know what those numbers meen? how can we possibly tell you what's best for YOUR car? what do you want? handling? wheel protection? do want to drop it?
Life Begins > 6800rpms
Rep Power: 349 get a tire thats made for a 7.5 width, some tires are made for 7" width only. im gonna say a definately but maybe b would fit. it depends on how low your drop is to avoid rubbing and camber wear issues.
The World Is Yours!
Rep Power: 301 make sure you get a warranty on tires from discount if you get tires, saves money when you get one free tire. but the 215/35 would be too small depending on your drop. the 215/40 probably the best.
Rep Power: 0 215/35 will actually give you a smaller overall diameter than stock. I'd go with 215/40 because that will only be slightly larger and will keep your speedo most accurate.
muttleytm
07-08-2015 04:13 PM
BootyDo
07-07-2015 06:06 AM
Causemo
07-05-2015 06:42 AM
