Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-13-2005   #1 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Thumbs up Drums--->Discs SPELLED OUT
Pictures fixed 2/2/06
This WILL be the last thread ever posted on the subject. I swear I'm gonna ban anyone who asks again. Post in THIS THREAD if you have questions about doing this. There is info in the FAQ, it is basic, this is a mix of that, the Honda manual on the subject and me tearing stuff apart. While I do not claim this to be 100% comprehensive, if you know a wrench from a hole in the ground, this is easy. It is a straight bolt on install, you don't need to modify anything... its just part for part swapping.
First you need to acquire a set of EP3 discs. EL discs for Canadians also will work. The more complete you can buy, the better, low miles is good too. If you build them, which I advise against because its expensive, you need knuckles, the hub and bearings, caliper assembly, wheel sensors and all the bracketry. Regardless, you need Si brake lines and EP3 or DC5 ebrake cables. I believe non abs cars will require a new proportioning valve although I can't confirm this. EX models don't need one, the ABS takes care of it.
Start by doing normal rear end work proceedures, jack the car, stands, pull the wheels.
You don't need too many tools, 10, 12, 14, 17 and 19mm sockets, a couple other basic tools. If you have ratcheting wrenches, they will come in handy, there's some tight spots.
First, remove the brake lines from the drums. Its up on the wheel well, you'll also need to remove the brake line bracket and save it for the new lines.
Next go into the car and remove the console. Disconnect the e-brake cables from the handle. You'll need to rotate the carrier until the wire comes up out of the slot on the side, then the pin will come out the top. Unbolt the 3 bolts that hold the cable to the underside of the car.
Then you'll need to remove the wheel sensor wires. On the right side, the plug is in the trunk. Pull up the carpet, you'll see a silver cover on the right side, just behind the seats. Pry it up to reveal the connector, unplug it and push it through the hole in the floor. There's also a bracket that holds it under the car, and one that holds it to the UCA. It also helps to undo the bolt that holds the muffler guard in place so you can see what you're doing when you go to put the new one in. Its the guard bolt right next to the sensor bracket. On the left, the harness is above the gas filler neck. Its a tight squeeze, but you can grab it.
With all the connections undone you can now unbolt the knuckle. First, mark the alignment cam so you know where to put it back later. The back bolt on the bottom of the knuckle is eccentric. If you look at it, there's marks on it... mark the one that lines up with the mark on the frame, or use a marker to mark where it goes.
(the red mark in the picture isn't exactly right, but if you look at the cam bolt next to it you'll see the marks I'm referring to)
Using a jack to support the knuckle, remove the UCA bolt first, then the alignment locknut. Once you've got the alignment nut off remove the front lower bolt. The knuckle should swing down now. With a small hammer or a socket handle, knock the alignment cam out. You should have the cam bolt and the big slotted nut. the knuckle should be loose, remove it.
Remove the stock wheel sensor from the drum. Its the oblong shaped thing in on the back that the orange plug is attached to. Remove the bolt then pry it out carefully. You'll need to do the same for the ones on the discs. Put the stock ones from the drums in the discs. Bolt them back in, toss the Si ones.
Everything else is just in reverse order. If you need to install brake lines on the discs, do it beforehand, make sure you use crushwashers with the new lines to prevent leaks. You can also change pads and/or rotors beforehand.
Bolt the lower front bolt in, but not all the way. If you tighten it you won't get the cam back in. Then reinstall the cam, lining up the marks. Install the locknut and keep your marks lined up. Torque the locknut to 43 ft-lbs. Tighten down the front bolt now, also 43 ft-lbs. Then swing the knuckle up and install the UCA bolt. 43 again.
Install the bracket on the brake line with the clip and connect the lines. Bolt the bracket back on the wheel well. No spec... just tight.
Feed the E-brake lines in through the floor. Connect them to the carrier attached to the handle and rebolt them to the floor pan. Don't forget to install the rubber floor seals.
The E-brake on the caliper is the sprung hook on top. Feed the line under the knuckle and through the hole in the bracket, then push the spring down and connect the line. The right side goes on pretty easily, the left is very tight. I found its easier to install if you connect the lines to the caliper first, then connect them to the handle. To connect them to the handle, loosen the adjustment nut as much as possible. Connect the LEFT cable FIRST, then rotate the carrier and connect the right cable.
Reconnect the wheel sensor wires and bolt the brackets down. Test the ebrakes to see if they're engaging by rotating the hub with the handle pulled. If they don't engage, tighten the nut above the carrier until they grab.
Then pump the brakes a couple times to partially fill the new brake lines, you'll need to thoroughly bleed the whole system.
Go gentle on them at first just to make sure everything is ok, and gradually get harder on them... they should work just fine. If you want to make sure they're engaging, use a marker and draw lines on the rotor.... they should be gone once you drive the car.
Estimated time to complete 3-5 hours
Have at it.
If you're real hardcore and you want to have the calipers pressure tested... the line pressure is about 770 psi to the fronts, 170 psi to the rear. This is the EX w/ ABS. I don't know how different the LX/DX proportioning is.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Sponsored Links
Old 05-13-2005   #2 (permalink)
pon55
Ultimate Member
pon55's Avatar
pon55 is just really nice pon55 is just really nice pon55 is just really nice pon55 is just really nice
Send a message via AIM to pon55
Awsome, thanks for posting! Printing now!
__________________
Civic minded old man/ low-loud-loven it!
http://www.myspace.com/pon55
RIP Diana,forever in our hearts and prayers.
pon55 is offline   Reply With Quote
Old 05-14-2005   #3 (permalink)
blouisgod
Life Begins > 6800rpms
blouisgod's Avatar
blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold
Send a message via AIM to blouisgod
those parts are hard to find lately for some reason...
Nice DIY!
__________________
2008 ASM Si Sedan w/ Navi and Summer Tires
blouisgod is offline   Reply With Quote
Old 05-14-2005   #4 (permalink)
Boilermaker1
Jap-Euro Fusion
I know of a 2 sets for sale right now.... and a junk yard with 3 more.
Old 05-17-2005   #5 (permalink)
clrumivier4life
Senior Member
clrumivier4life's Avatar
clrumivier4life is an unknown quantity at this point
Send a message via AIM to clrumivier4life
How much could I find these for? And anyone selling?
clrumivier4life is offline   Reply With Quote
Old 05-18-2005   #6 (permalink)
liljoe
liljoe's Avatar
liljoe is an unknown quantity at this point
Has anyone with this swap done on a non-ABS car changed the proportioning valve. I have not, but I am wondering how much difference I would notice??
__________________
1.5 million battered women... and all this time I've been eating mine plain......
liljoe is offline   Reply With Quote
Old 05-18-2005   #7 (permalink)
blouisgod
blouisgod's Avatar
how much? maybe they are hard to find here, si's were selling for 14k new last year- there hasnt been much demand for them.
__________________
Old 06-02-2005   #8 (permalink)
Pn0ybOiLiKehOy
Diamond Member
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
hmmm can u make a list of exactly what u need for this?? im having trouble reading what i need and whats optional. LOL also around how much would this cost?
Pn0ybOiLiKehOy is offline   Reply With Quote
Old 06-02-2005   #9 (permalink)
wonderz
Ultimate Member
wonderz's Avatar
wonderz is on a distinguished road
Send a message via AIM to wonderz
Quote:
read the faq. hondaluver(sp?) already listed all the parts that is need.
as for the price, if u get it from honda, it would be around $700 total for brand new parts.
junk yard and other places would run u between three to five hundred.
if you want "professional installation" that would be extra of course.
wonderz is offline   Reply With Quote
Old 06-02-2005   #10 (permalink)
xRiCeBoYx
Your neighborhood friendly RiCeBoY!
Location: Las Vegas, NV (Stationed in Bremerton, WA [CVN 74])
xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all
Send a message via AIM to xRiCeBoYx
*GASP* lovely DIY... you rock
__________________
PLEASE BUY MY STUFF!!
...Slowly going back to N/A for now...
..I'm a sad panda..
.my car is crying on the inside.
T.E.A.R.S. Crew Member #3
LETS GET THE TIRE CALCULATOR BACK!
S370HSSV-0773H
xRiCeBoYx is offline   Reply With Quote
Old 06-08-2005   #11 (permalink)
blouisgod
blouisgod's Avatar
rsx/si e brake cables, rear knucles, wheel sensors, rotors, dust covers, calipers, pads, brake lines and nuts/bolts, bleeder bottle for the install.
__________________
Old 06-08-2005   #12 (permalink)
rickinthescv
Diamond Member
rickinthescv's Avatar
rickinthescv will become famous soon enough rickinthescv will become famous soon enough
Send a message via AIM to rickinthescv
You can re-use the brake sensors from the EX. As they are the same part. You only need to remove the bolt holding them to the hub, then carefully pry them out, that way you do not have to unplug them from the inside of the car, saves time.
Canadian EL parking brake cables work best, as they are a little longer, but the Si's will work with a little stretching. And on my EX, I removed the stock proportional valve and replaced it from the SI's.
__________________
2001 Civic EX Coupe
Satin Silver
Eibach Sportlines
RH Evolution C2
Kumho 205/40HR-17
rickinthescv is offline   Reply With Quote
Old 06-16-2005   #13 (permalink)
HondaLuver
Its a celebration bitches!
HondaLuver's Avatar
Send a message via AIM to HondaLuver
blah blah blah
__________________
01 SSM em2 k24 hybrid
06 Red CBR600RR
Status:
01 SSM em2 built k24bar'd NA tune(till turbo time)...240.7 hp and 190.9 tq
Stuff for sale
HondaLuver is offline   Reply With Quote
Old 06-18-2005   #14 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
if I have ep3 e-brake cables..should I try to use them or just buy dc5 cables?
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 06-18-2005   #15 (permalink)
EM2typeflex
Diamond Member
EM2typeflex is an unknown quantity at this point
just use the ep3 cables, I did and they work fine
EM2typeflex is offline   Reply With Quote
Tags
1991 , abs , brakes , civic , conversion , disc , drum , honda , instructions , picture , rear , reconnect , removing , rsx , spelled
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
what do u think of my civic usafstud South Cali 17 07-18-2004 02:17 AM
Rear brake conversion RedDragon333 Wheels,Tires & Brakes 84 09-15-2003 06:42 AM
Project K20a2 Civic Type S in progess (update #3 k20 is in) Hawk Honda Civic Member's Rides 211 08-23-2003 05:00 AM
Rear drum to disc brake conversion??? CivicLX620 Wheels,Tires & Brakes 19 06-29-2003 10:29 PM
RSX Rear Brakes Fit?!?!?!?!? Pir8pete Honda Civic DIYs and Civic Tech Chat 10 05-01-2002 01:00 AM
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
