Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-23-2005   #61 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
HOLY SHIT REALLY?!?!?! Read the first line of post number 1 To remove this ad, register today for free or log in if already registered!
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Sponsored Links
Old 11-23-2005   #62 (permalink)
xRiCeBoYx
Your neighborhood friendly RiCeBoY!
Location: Las Vegas, NV (Stationed in Bremerton, WA [CVN 74])
xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all xRiCeBoYx is a name known to all
Send a message via AIM to xRiCeBoYx
sorry.. i suck at life..
__________________
PLEASE BUY MY STUFF!!
...Slowly going back to N/A for now...
..I'm a sad panda..
.my car is crying on the inside.
T.E.A.R.S. Crew Member #3
LETS GET THE TIRE CALCULATOR BACK!
S370HSSV-0773H
xRiCeBoYx is offline   Reply With Quote
Old 12-03-2005   #63 (permalink)
mkingk2
Senior Member
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
Send a message via AIM to mkingk2
I won't argue with that.
jk lol
mkingk2 is offline   Reply With Quote
Old 12-03-2005   #64 (permalink)
blouisgod
Life Begins > 6800rpms
blouisgod's Avatar
blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold
Send a message via AIM to blouisgod
damn NAVy peeps
__________________
2008 ASM Si Sedan w/ Navi and Summer Tires
blouisgod is offline   Reply With Quote
Old 12-05-2005   #65 (permalink)
mrDFWmechanic
mrDFWmechanic's Avatar
Send a message via AIM to mrDFWmechanic
sux the pics dont work now
mrDFWmechanic is offline   Reply With Quote
Old 12-29-2005   #66 (permalink)
chefjnr
Senior Member
chefjnr is an unknown quantity at this point
ran into a problem....got what I thought ws a 2003 civic si 4 lug rear disc brake parts to do the conversion. Everything bolted on perfectly and no problems, until I tried to put on the ebrake cable. The ebrake cable that was supplied DOES NOT FIT- even had a mechanic at his shop try, it is about 2" too short. I also got brand new OEM rotors, thats when i discovered that the OEM rotors for the civic are 9.25"- the ones i pulled off my donor parts were 10.25"- the 9.25" do not fit. Is it possible that the junkyard sent me a diff. donor vehicle part then requested- maybe something that works also? The calipers are OEM, but the rotors have no part number stamped on them. I sent SP one of the OEM rotors to make me the diamond slotted ones in the exact same size, so that issue will be fixed. What do you think I need to do about the ebrake cable? Any guess as to what vehicle the donor parts really came off of? Acura says the 02-03 4 lug civic si did not come in a 10.25" rotor size, so I suspect I got a diff. donor part. Should I get a 2003 or 2004 RSX-S Ebrake cable? I thought I read somewhere they were about 2" longer.
Thanks for the help.
__________________
K20A (KPRO) 10.5:1 Mahle pistons, oliver rods, cometic head gasket, ARP bolts, KMS 1mm oversized valves, 650cc RC injectors, Port and Polish, All stainless hoses, walbro fuel pump, S2000 oil pump,alternator (190Amp),Turbo intercooled and N'tercooler, turbo timer, Profec-B Spec 2, limited slip, short shifter, lightened flywheel, Drive Shaft Shop stage 3 axels, 17" Trak Lite 2's, Koni Yellows, Tanabe springs, Neuspeed U/L strut bars, Progress Rear sway, Skunk2 custom dual exhaust, sparco torinos, verticle doors
chefjnr is offline   Reply With Quote
Old 12-29-2005   #67 (permalink)
Boilermaker1
Jap-Euro Fusion
I got the Si Cables to work by loosening up the handle carrier until it was almost off the adjuster screw. RSX cables are a touch longer. Use those.
As far as the rotor size, they should be 9 and something. The fronts are 10.25".
__________________
2002 Civic
Old 12-29-2005   #68 (permalink)
blouisgod
blouisgod's Avatar
have you loostened the carrier bolt inside the car to mount the ebrake cables? if that doesnt work, try dc5 cables are way longer than the ep3s like boiler said. so long in fact you have to zip tie the extra cable down along the rear arms, youll see what i mean if you get the rsx cables; it makes working with them so much easier.
did you get the actual ep3 hubs? if you need new rotors for those, you need to order 02,03 civic si rotors. obviously.
__________________
Old 01-02-2006   #69 (permalink)
Axxe
Member
Axxe's Avatar
Axxe is an unknown quantity at this point
I still can't beleive that Honda didn't stick rear discs in their sport compact.
Good right up Boiler, I have a feeling I'm going to be doing quite a few of these up in my neck of the woods.
Axxe is offline   Reply With Quote
Old 02-02-2006   #70 (permalink)
Boilermaker1
Jap-Euro Fusion
LINKS FIXED. No more whining about pictures
__________________
2002 Civic
Old 02-23-2006   #71 (permalink)
elitecivicex01
Diamond Member
elitecivicex01's Avatar
elitecivicex01 will become famous soon enough elitecivicex01 will become famous soon enough
Send a message via AIM to elitecivicex01 Send a message via Yahoo to elitecivicex01
Question parts inquiry....??
got THIS setup over a year ago. after reading the DIY by Boilermaker, sounds like a feasible task. just wanted to post pics to inquire if what i got for $200 cash from a friend down in Miami, FL seems like the whole deal? all i need? anything extra? need more specific pics?
please advise. i am interested in doing this swap soon.
btw, i drive a 2001 Civic EX coupe w/ ABS & right now im rolling on blown OEM shocks/struts and Neuspeed Race springs. approximately 2 years of age on this setup. EVENTUALLY i WILL be upgrading to the OmniPower street setup whenever this stuff comes out.... (obviously)
__________________
http://www.civicforums.com/forums/signaturepics/sigpic11722_1.gif
HAVE: RR 2007 Honda Civic 4DR Si
SOLD: RR 2001 Honda Civic 2DR EX (5-speed)
Joey's MySpace
FA5 FTW!!!!!!!
...::HID-tested, Carbon Fiber approved::...
elitecivicex01 is offline   Reply With Quote
Old 02-23-2006   #72 (permalink)
K20me
K20me's Avatar
K20me is a jewel in the rough K20me is a jewel in the rough K20me is a jewel in the rough
Wow you got a whole lot more than you needed. You won't need the arm or the shocks or the stock camber arm. I can't tell if the E-brake cable is there. Looks like it is on the second picture. Anyway, looks like you have everything you need.
K20me is offline   Reply With Quote
Old 02-23-2006   #73 (permalink)
SleakCivic02
Member
SleakCivic02's Avatar
SleakCivic02 should not be trusted SleakCivic02 should not be trusted
Send a message via AIM to SleakCivic02 Send a message via MSN to SleakCivic02 Send a message via Yahoo to SleakCivic02
this diy sux cuz you arent telling where you can get these parts. what the **** is ep3? just say type r. where the **** am i suppose to find parts like those. junk yards, yeah right, all the parts from the junk yard around here are from the 80 cars. sorry your diy is not spelled out, the process is ok but the parts selection sux.
__________________
Boosted!
With problems... sux
SleakCivic02 is offline   Reply With Quote
Old 02-23-2006   #74 (permalink)
Boilermaker1
Jap-Euro Fusion
You've got far more than you need there. All you need is the knuckle + brakes. You can swap over the whole arm, but its a lot of pain in the ass for nothing. You don't need the shock either. Use the knuckles, sell the shocks and control arms back to the junkyard.
__________________
2002 Civic
Old 02-23-2006   #75 (permalink)
Boilermaker1
Jap-Euro Fusion
Quote:
Oh cry me a river.
Do you need someone to hold your hand and take you in your stroller to find the parts for you? Boohoo.
Jeez, quit whining, get on the forums and find the damn parts.
No one else seems to have any trouble running down the parts they need to do this, and there's absolutely nothing wrong with the DIY. If you can't figure out how to undo 3 bolts a brake line and a snap clip, you've got no business working on the car at all. Period.
__________________
2002 Civic
Tags
1991 , abs , brakes , civic , conversion , disc , drum , honda , instructions , picture , rear , reconnect , removing , rsx , spelled
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
what do u think of my civic usafstud South Cali 17 07-18-2004 02:17 AM
Rear brake conversion RedDragon333 Wheels,Tires & Brakes 84 09-15-2003 06:42 AM
Project K20a2 Civic Type S in progess (update #3 k20 is in) Hawk Honda Civic Member's Rides 211 08-23-2003 05:00 AM
Rear drum to disc brake conversion??? CivicLX620 Wheels,Tires & Brakes 19 06-29-2003 10:29 PM
RSX Rear Brakes Fit?!?!?!?!? Pir8pete Honda Civic DIYs and Civic Tech Chat 10 05-01-2002 01:00 AM
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
