Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-20-2005   #16 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Quote:
Originally Posted by SkipBarber
if I have ep3 e-brake cables..should I try to use them or just buy dc5 cables?
Attach them to the brake caliper FIRST. Then hook them up to the handle. They're about an inch and a half short, so you're going to need to loosen the carrier on the handle post as much as possible, then tighten it back up once you got the cables in.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Sponsored Links
Old 06-27-2005   #17 (permalink)
rumptis
New Member
rumptis's Avatar
rumptis is an unknown quantity at this point
What about us guys with 4 doors...will the ebrake cable reach as far as we need?
__________________
2005 Civic EX Special Edition Manual
rumptis is offline   Reply With Quote
Old 06-27-2005   #18 (permalink)
Boilermaker1
Jap-Euro Fusion
Quote:
The wheelbase is the same isn't it?
And the console is in the same place isn't it?
So what would the problem be?
__________________
2002 Civic
Old 06-27-2005   #19 (permalink)
blouisgod
Life Begins > 6800rpms
blouisgod's Avatar
blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold blouisgod is a splendid one to behold
Send a message via AIM to blouisgod
I picked up a set of rsx cables on clubrsx.com for 30 shipped. The rsx cables are a touch longer than the ep3's.
__________________
2008 ASM Si Sedan w/ Navi and Summer Tires
blouisgod is offline   Reply With Quote
Old 07-07-2005   #20 (permalink)
etdigitalis
Member
etdigitalis's Avatar
etdigitalis should not be trusted
Could RSX E-brake cables be the answer?
Quote:
let me know how this went.
i bought the ep3 cables and after installing them had a slight drag on the driver side. i have since completely disconnected them from the lever with the hopes of finding a canadian replacement. if they work-out, without having to stretch or bend something, i'd like to give it a try.
etdigitalis is offline   Reply With Quote
Old 07-10-2005   #21 (permalink)
Boilermaker1
Jap-Euro Fusion
How loose did you have the cables on the handle? You literally have to run the adjustment nut all the way down until there's nothing hanging out the back, then adjust it back up until it almost catches but doesn't.
__________________
2002 Civic
Old 07-11-2005   #22 (permalink)
etdigitalis
Member
I loosened the cable quite a bit. Definately to the point where nothing was hanging out of the back... but I suppose I could've gone further. It was more of the fact that the difference in length between the two cables was pushing the pivot limits of the equalizer bar. Also, the adjustment nut was getting hung up on the cable bracket, preventing me from being able to place the lever all the way in the down position.
It was also 95F and I was sweating it out in my garage
I dunno... maybe I'll give it another shot when it cools down a bit.
Old 07-13-2005   #23 (permalink)
skipbarber
skipbarber's Avatar
skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all skipbarber is a name known to all
Send a message via AIM to skipbarber
did anyone notice that its not possible to use a different proportioning valve with the lx/dx cars? the lx/dx valve has 2 input ports and 4 output ports, for a total of 6. the EX proportioning valve has 4 outputs, since the inputs go to the abs modulator, and the SI doesnt have a proportioning valve at all since its all tied into electronics for traction control etc. ...so, i cant really do much with discs, oh well, they look good i guess
__________________
sig by speedfoos
The DX resource site.
-2002 SSM EM2 - D17A1/A2 hybrid turbo(vtec, non-egr, steel oil pan, Hondata managed) 240 fwhp, 210 lb/ft tq @ 9.5 psi
-1991 MK3 Toyota Supra turbo (full cage, track setup) TBA
-2008 Honda NPS50 Ruckus - Stock 5 rwhp
skipbarber is offline   Reply With Quote
Old 07-13-2005   #24 (permalink)
etdigitalis
Member
the si proportioning valve is called a 4-way joint (item 31 on the diagram).
i hadn't noticed the different valve on the EX and LX/DX before. that sux, man.
is there anyone out there that's done this conversion on a non-ABS model? or anyone that has upgraded to ABS? that sounds like it would be a real bitch.
Old 07-13-2005   #25 (permalink)
skipbarber
skipbarber's Avatar
yea, i saw that, but i dont think the 4 way joint on the SI does any proportioning. I think it just keeps balance between the adjacent corners.
__________________
sig by speedfoos
Old 07-16-2005   #26 (permalink)
flowerpowerlove
just breathe...
flowerpowerlove's Avatar
flowerpowerlove is an unknown quantity at this point
so how much are you all finding those disc's for? i gonna head to the junkyard today maybe and dont want to get raped...
flowerpowerlove is offline   Reply With Quote
Old 07-18-2005   #27 (permalink)
HondaLuver
Its a celebration bitches!
HondaLuver's Avatar
Send a message via AIM to HondaLuver
^^^ read post # 9
__________________
01 SSM em2 k24 hybrid
06 Red CBR600RR
Status:
01 SSM em2 built k24bar'd NA tune(till turbo time)...240.7 hp and 190.9 tq
Stuff for sale
HondaLuver is offline   Reply With Quote
Old 07-22-2005   #28 (permalink)
sweeteli99
Super Member
sweeteli99 will become famous soon enough sweeteli99 will become famous soon enough
having a bit of a problem on this as well, i have everything in, on the right side, except for the ebrake cable, i can't get the ebrake onto the caliper... i was going to try to take the brakes out, and do them that way, not sure if that'll work, but i just spent 4hrs on one side, and am running out of options, if it doesn't work, i'll get dc5 cables. I loosened the cable a lot too, can't see the bolt in it. anyways, anyone got any other tips for this ?
i found the DIY to be a little useful, pretty easy mod, just time consuming, i think the other side will go 100x faster...
sweeteli99 is offline   Reply With Quote
Old 07-22-2005   #29 (permalink)
Boilermaker1
Jap-Euro Fusion
put it on the caliper first, then on the handle.
__________________
2002 Civic
Old 07-22-2005   #30 (permalink)
sweeteli99
Super Member
if i were to do that, i would barely be able to get the handle on, it was hard doing it as it is, its not on the caliper, am i supposed to not have it all bolted up, all the brackets are bolted in, under the car. thanks for your help btw.
Tags
1991 , abs , brakes , civic , conversion , disc , drum , honda , instructions , picture , rear , reconnect , removing , rsx , spelled
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
what do u think of my civic usafstud South Cali 17 07-18-2004 02:17 AM
Rear brake conversion RedDragon333 Wheels,Tires & Brakes 84 09-15-2003 06:42 AM
Project K20a2 Civic Type S in progess (update #3 k20 is in) Hawk Honda Civic Member's Rides 211 08-23-2003 05:00 AM
Rear drum to disc brake conversion??? CivicLX620 Wheels,Tires & Brakes 19 06-29-2003 10:29 PM
RSX Rear Brakes Fit?!?!?!?!? Pir8pete Honda Civic DIYs and Civic Tech Chat 10 05-01-2002 01:00 AM
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
