Wheels,Tires & BrakesPost Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
by and large.... the hammer method works best. over time and alignments they slip around and get stuck together. Its best to replace it once you get it out.
Just to clear things up as long as I have and ex (abs) I dont need a new proportioning valve? It will take care of itself? Also what year SI do I need these brakes off of I would like to get it off the newest year possible. I think 2003 is the last year with 4 lug? 2004 they started doing 5? Is this correct? If so are 02-and-03 exactly the same? like can I mix and match if need be?
everything has to be off an 02 or 03 civic si or 01-05 el. yes you can mix and match. a new ppv isnt required on any model. you dont really want to mess with the brake bias anyway unless you really know what your doing. if anything you would want a new brake mc. but the stock equipment is perfectly fine for the swap
__________________ "It's not hard, it's just not easy" !!!!7thGen!!!! Koni/GC 6.6kg Front 9.2kg Rear, Ksport camber/caster plates, Megan rear Camber Kit, eBay Fogs, DIY Blacked out headlights, JVC KDAR-480 HU, DIY Red LED Dash Lights, DC5 sidemarkers, magnaflow exhaust, EP3 Seats, Skunk2 Rear LCAs, progress rear bar....more to come
yes well you would have more psi of fluid pressure when braking so im assuming it would help lower braking distance but im just using my stock lx mc so i couldnt honestly tell you
First you need to acquire a set of EP3 discs. EL discs for Canadians also will work. The more complete you can buy, the better, low miles is good too. If you build them, which I advise against because its expensive, you need knuckles, the hub and bearings, caliper assembly, wheel sensors and all the bracketry. Regardless, you need Si brake lines and EP3 or DC5 ebrake cables. I believe non abs cars will require a new proportioning valve although I can't confirm this. EX models don't need one, the ABS takes care of it.
Remove the stock wheel sensor from the drum. Its the oblong shaped thing in on the back that the orange plug is attached to. Remove the bolt then pry it out carefully. You'll need to do the same for the ones on the discs. Put the stock ones from the drums in the discs. Bolt them back in, toss the Si ones.
ok.. so if im reading this correctly, you need the abs sensor from the donor car... but why are you swapping the abs sensor from the drum to the disk knuckle?
__________________ 01 ES2, if you dont know what that is.. SEARCH
78 X1/9, if you dont know what that is.. i dont blame you
Honda Trained Technician
Project 5lug: Coming Soon
