Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-12-2006   #46 (permalink)
stock
Member
stock is an unknown quantity at this point
Just checked my rear brakes and they're still good. What do you guys use to clean the brake dust off?
My Honda dealership is recomending that they "Service front and rear brakes". What is there to service since the front pads/discs and rear shoes/drum are good?
Are they trying to charge me money just to clean the brake dust off?
stock is offline   Reply With Quote
Sponsored Links
Old 06-12-2006   #47 (permalink)
boxcarracer
Platinum Member
boxcarracer's Avatar
boxcarracer is a jewel in the rough boxcarracer is a jewel in the rough boxcarracer is a jewel in the rough
Send a message via AIM to boxcarracer
Great Diy Just What I Needed. I Frucked Them Up And Needed A Diy Savedme Like 10 Min<33
"STEALERSHIP...." ANSWER.....YES SIR THEY ARE
__________________
boxcarracer is offline   Reply With Quote
Old 06-12-2006   #48 (permalink)
Boilermaker1
Jap-Euro Fusion
Boilermaker1's Avatar
Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold Boilermaker1 is a splendid one to behold
Use a vaccum cleaner or other suction device that captures the dust. DO NOT blow it away with compressed air. You don't want the dust airborne, its quite harmful to your lungs despite it being asbestos free.
__________________
2002 Civic
Closet Built... 236.7 HP, 187.3 ft-lb
http://www.civicforums.com/forums/19...-car-sale.html
2008 Audi A3 2.0T S-Line
Boilermaker1 is offline   Reply With Quote
Old 09-30-2006   #49 (permalink)
highwayman
New Member
highwayman's Avatar
highwayman is an unknown quantity at this point
here's a link to an easier way to put the shoes/springs/clevis back on.
http://www.hondatuningmagazine.com/t...chback_brakes/
putting them back on only took me 25 minutes per side with this method on my '93 civic.
highwayman is offline   Reply With Quote
Old 06-06-2007   #50 (permalink)
reddawnman
Senior Member
reddawnman's Avatar
reddawnman is a name known to all reddawnman is a name known to all reddawnman is a name known to all reddawnman is a name known to all reddawnman is a name known to all reddawnman is a name known to all reddawnman is a name known to all reddawnman is a name known to all
Send a message via AIM to reddawnman
Re: DIY Drum Brake Shoe Replacement
Jesus Fscking christ, this is a PITA.
I'm done with one wheel, going to bed and will do the second tomorrow.
FYI, for those of you doing wheel cylinders too, to get the 2nd screw that holds the cylinder located (conveniently) right in front of the shock tower where you have no working clearance, you need to loosen the 4 14mm bolts holding the wheel backing plate. Use wd-40. The shit broke a 14mm wrench from harbor freight when i forgot the wd-40. Cheap chinese crap, yes, but i want all to learn from my mistakes :-)
As far as the springs go, I did it by hooking the long top spring up FIRST. I then opened the bleeder screw on my wheel cylinder and pushed the pistons in, letting excess fluid drip out to a container. Installed the shoes on either side, with the adjusting rod broken into two parts... the first part i had hooked into the parking brake / bitch-to-get-off U-clop shoe when I installed it. The "short" part that goes with the self adjuster I installed after getting everything "hanging" in place. The next to last thing I did was to spring up the self-adjuster and get that in place. Last was the short bottom clip on the shoe.
I also did my valve clearance today, but one of the bolts broke off into the head when i was putting the valve cover back on (friggin wrench was set at 6lbs, spec is 7.2, CRACK!). Nobody stocks the part, so screw it for a couple weeks. Anybody have that happen to them before? I'm assuming I need to get an ez-out from sears or something and drill the center of the stuck part out so I can loosen it.
__________________
My Timing Belt DIY
Coolant Flush DIY
"If it's so essential, ask yourself why you've been able to live without it before now."
Try doing something nice for a total stranger, then look back at your car. Notice that the good feeling you get from helping lasts all day, but you constantly have to put stuff on your car to feel better.
Good Thoughts, Good Words, Good Deeds
reddawnman is offline   Reply With Quote
Old 10-28-2007   #51 (permalink)
ancientpimp
New Member
ancientpimp is an unknown quantity at this point
Thank you, thank you, for all the info here lord, i was gonna ask how to bleed the brakes cuz i just changed the !gnikcuF shoes (my next car would all be disc brakes dangit!) and my brakes are spongy but that link also answered my question,lol.
ancientpimp is offline   Reply With Quote
Old 11-05-2007   #52 (permalink)
linas58
New Member
linas58 is an unknown quantity at this point
So when you go to pound the old drum off doesn't it get hung up on the brake shoes? Don't you need to release the self adjuster so that the drum slides over and off of the brake shoes? I'm thinking that as the shoes wear a trough into the drum and wont slide off. Is that a problem?
linas58 is offline   Reply With Quote
Old 12-26-2007   #53 (permalink)
aliefjoker
Member
aliefjoker's Avatar
aliefjoker has a spectacular aura about aliefjoker has a spectacular aura about
^Depending on your drums, sometimes you can just grab them and twist them side to side and they'll pop off. If you have to bang them, hit on the outer part of the drum in between two studs about 2-4 times and rotate to the next pair of studs. There's no getting hanged on the shoes. Disassembly is easy, reassembly is the PITA
aliefjoker is offline   Reply With Quote
Old 08-24-2008   #54 (permalink)
Matt300
New Member
Matt300 is an unknown quantity at this point
Damn...spent about 3 hours on this. I'm seriously gonna consider just taking it in next time. But my '05 is at 47k, so I'm thinking the next time it gets done I'm just opting for the disc conversion.
Thanks for the DIY though - clear enough that a newbie like me was able to give it a go!
Matt300 is offline   Reply With Quote
Old 09-18-2008   #55 (permalink)
timmygregory
New Member
timmygregory is an unknown quantity at this point
Are these instructions the same for a 2001 Civic EX Automatic?
thanks
Tim
timmygregory is offline   Reply With Quote
Old 10-16-2008   #56 (permalink)
naughton
New Member
naughton is an unknown quantity at this point
These clips hold the shoes in place. With the needle nose pilers and a screwdriver, depress the spring and turn the pin that holds the shoes in place. There's one per shoe.
naughton
asciisol
naughton is offline   Reply With Quote
Old 10-16-2008   #57 (permalink)
stuartdenley
New Member
stuartdenley is an unknown quantity at this point
wheels are probably the hardest part of your car. Break dust is a mixture of carbon fibres, metal filings and adhesive residues I suggest you to use low dust break pads and fit dust shields these sit between the rim and the hub.
__________________________________________________ _____
Compra pc portatili Gender Reassignment Surgery
stuartdenley is offline   Reply With Quote
Old 04-25-2009   #58 (permalink)
schreibers
New Member
schreibers is an unknown quantity at this point
Great tutorial for a first timer like myself.
I'll be honest it took me three hours to do this today. 2.5 for one and thirty minutes for the other. What a freaking pain in the ass getting that top spring on/off. Unfortunately on the first one I did I punctured a small hole in the boot of the cyclinder while getting that top spring off so I think I need a new cylinder as well as to bleed my brakes.
Thanks again for the DIY!
schreibers is offline   Reply With Quote
Old 06-08-2009   #59 (permalink)
seeley
New Member
seeley is an unknown quantity at this point
Nice tutoiral. I just did mine yesterday. I'm a bit sore today in the fingers. The top springs and clip holding the ebrake lever can be tough.
On the ground, I first assembled both shoes with e-brake lever, adjuster lever, clevis adjuster rod, and top spring and then put that onto the hub. Then added the adustment spring and bottom spring. First time I ever did drums. I know I need to bleed at least one side because I hit the piston and it came out too far and boot popped off and leaked a bit. But hey, first time for everything. I also used the Honda Repair manual which was a big help. I was suprised to notice that all four brake shoes are identical.
OP: I don't know if anyone noticed, but one of your photos shows the ebrake lever on backwards.
seeley is offline   Reply With Quote
Old 07-20-2009   #60 (permalink)
pheaton
A descendent of 2k1civic.com
pheaton's Avatar
pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light pheaton is a glorious beacon of light
Send a message via AIM to pheaton Send a message via MSN to pheaton Send a message via Yahoo to pheaton
I did it. . I can see how once you've done it once you can do it quickly the 2nd time. The first side is going to be a learning experience, but the other side is smooth. .
Those clips can be a pain and the top spring is a pain, but other than that. . It's not bad.
Definately bleed the system, especially if you pop the piston out like I did repeatedely on the 1st side.
All in all it was a PITA, but not the worst thing to do. . They were definately due for changing, but they weren't as bad as I thought for having 105k on the car and never changed.
Since I'm a glutton for punishment, I'm doing the timing belt next weekend!
__________________
- Stay in front, that way you don't have to worry about passing anyone.
pheaton is offline   Reply With Quote
Tags
1993 , brake , brakes , change , civic , diy , drum , drums , honda , rear , remove , removing , replacement , shoe , shoes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Honda Civic Forum Replies Last Post
Brakes Squeek When Depressed whitedaze Wheels,Tires & Brakes 14 06-23-2004 03:17 PM
how do i change the back brakes CvC-v01 Wheels,Tires & Brakes 27 12-07-2003 05:55 PM
driving with handbrake pulled slamtank Honda Civic DIYs and Civic Tech Chat 19 08-20-2003 01:52 AM
What Brake Rotors should i get??? nightkids1 Wheels,Tires & Brakes 22 05-23-2003 03:03 AM
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
