torque of caliper bolts?
Old 02-11-2005
thoughthard's Avatar
thoughthard is an unknown quantity at this point
Well, I might be attempting to change the front pads on my g/f's 03 EX coupe with the help from Grey's DIY, and http://members.fortunecity.com/4jacks/brakes.html. Just a few questions though...
If the rotors are perfectly smooth, with no ridges, is resurfacing neccessary?
What is the torque specs of the bolts circled in red and blue?
Also, I found a Honda dealer that will change just the pads for $99. Good deal? If the rotors need resurfaced, it is another $90. A closer Honda dealer will install pads and resurface rotors for $167.02. Just some other options, if I decide not to do it...
Old 02-11-2005
streetglower's Avatar
the torque on the red circled bolts is 25 lbf.ft and the ones in blue are 79.6 lbf.ft. Just get some performance pads and rotors and do it yourself. It is really easy.
Old 02-11-2005
Thanks. Just double checking before I attempt the job. I found 125 ft-lbs. somewhere else, but that sounded a bit extreme.
Old 02-11-2005
Jap-Euro Fusion
Boilermaker1's Avatar
125 is the correct torque. Thats what it says on the back of the brembo box as well. Crank them on.
Old 02-11-2005
Hmmm...
So it is 125 for all four bolts?
Old 02-11-2005
Jap-Euro Fusion
The 2 that hold the caliper to the hub are 125. The slider bolts, I'm not sure.
Old 02-11-2005
Well, two down, two to go...
Old 02-12-2005
Slowest 7thgen in the GTA
phuviano's Avatar
125 lb ft of torque. Damn, I didn't think it was that much.
Do we have a FAQ on this website that show torque specs for certain bolts on our cars. If not, I think someone or some people should compiled one.
OT: I have a neuspeed strut bar, what is the torque spec on the bolts I tighten down??
I read somewhere 33 lb ft of torque. I'm not sure though.
Old 02-12-2005
and... what about if the rotors are perfectly smooth, with no ridges, is resurfacing neccessary?
Old 02-12-2005
yes that is too much. From the service manaul it says 79.6 lbf.ft
Old 02-12-2005
no it is not necessary. But if you have stock rotors, then I would upgrade to brembo blanks.
Old 02-12-2005
Phil_Qc's Avatar
Phil_Qc is an unknown quantity at this point
When I replaced the pads...
When I replaced the pads the first time on my
2004 Civic, I did the reverse engineering (spell?)
with my torque wrench. It click at 100 ft/lbs...
Philippe
Old 02-12-2005
79.6 for which ones???
Old 02-12-2005
bolts that hold the bracket to the knuckle.
Old 02-13-2005
Just got done with the job. Used Satisfied Pro Ceramic pads. Extremely easy.
Opened up the brake fluid reservoir first. They suggested using a c-clamp to slowly compress the caliper first, so I did that. The first side, I loosened the two blue circled bolts, removed the top one, and tried to swing the caliper up, as someone suggested. That didn't work, so I tried the other. No luck, so I put those back in. I removed top red circled bolt, and tried to swing the caliper, but the brake line didn't like that. Replaced that bolt, and removed the bottom. Swung the caliper up, supported it with a bent clothes hanger, replaced pads, swung caliper down, replaced bolt, and torqued to specs that streetglower suggested.
On the second side, skipped all the unnecessary steps I took on the first side.
So far, okay...
Thanks everyone for the input!
Old 02-13-2005
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
^^so in the end you just removed the bottom red one?
Old 02-13-2005
Yeah.
Old 02-13-2005
So far, okay...
now you just need to bleed them since you now have air in the system since you opened the master cylinder to the atmosphere.
Old 02-13-2005
Make sure you have a crescent wrench for the flat sided washer just on the other side of the caliper, the one between it and the rubber boot.
Old 02-13-2005
Really? Ahh crap
Old 02-13-2005
Really? Ahh crap
yup, I am about to buy a pressure bleeder system so I can do it myself, I am not up to that 2 person method.
Old 02-13-2005
EX4Dr's Avatar
EX4Dr is an unknown quantity at this point
What the hell are you talking about? Opening up the reservoir does NOT require bleeding. The only time you need bleeding is if your reservoir gets emptied to a point where the fluid is low enough to suck air or if you remove the caliper piston. You can bleed it as a precaution but most likely it is unnecessary. Also changing your brake pads does not require you to remove the reservoir cap. The cap itself has a vent on it. That means the fluid in the reservoir is always exposed to the atmosphere. As the pad wears, the fluid will get lower. The vent is there to allow air to displaced the lowered fluid level.
Old 02-13-2005
^^^ Hopefully correct, so I don't have to bleed brakes...
Old 02-14-2005
Phil_Qc's Avatar
you don't need to bleed...
but you should... the pedal feel will be better.
No air have passed through the system if you
only open the reservoir.
Phil.
Old 02-14-2005
Phil.
Well I always thought it did. I guess I learn something new everyday.
SammySC
121
04-07-2017 07:43 PM
UltraHDGames
06-08-2016 05:16 PM
rovafa2002
09-28-2015 06:57 PM
2002ExCivic
22
09-28-2015 08:29 AM
Junquito89
09-27-2015 10:22 PM
Quick Reply: torque of caliper bolts?
