what to do when i get new rotors and pads?
Jap-Euro Fusion
Rep Power: 399 Bed the pads (break them in) and its usually wise to do a brake system bleed. DIY is somewhere in this forum.
Jap-Euro Fusion
Originally Posted by Nodnero
Dont install both at the same time, you wanna get the pads worn in first and then the rotors.
Installing them at the same time is fine. All it means is that you will doing the rotor seasoning and pad bedding procedure at the same time if you so choose. Here's what you need to do to get the most performance out of you new brake components.
1) For the first 200 - 300 miles, do the usual break-in by driving and braking lightly. It just means drive like all normal drivers (not spirited driving). Try avoiding any panic braking or use your brake excessively on long down hills (better to use lower gears to help out in long down hill situations). This break-in period will heat the brake components to sufficient temperature to burn-off/evaporate any cleaning agents or oil used in the manufacturing of the brake components.
2) After the usual break-in period. Perform the rotor seasoning and pad bedding procedure to get the most out of your brakes. Since both the rotor and pads are new, this procedure can be done at the same time. Rotor seasoning is really a heat cycling procedure by performing a series of gradually intensfying braking stops to alter the molecular crystal structure of your rotors to minimize future warpping of the rotors. The bedding procedure is a very similar procedure designed to deposite a layer of pad material onto the rotors to increase the coeficient of friction - thus stronger braking power. You can following the link below to find out how to do these procedure.
<a href="http://www.baer.com/Support/TechTips.aspx"> Seasoning and Bedding Procedures </a>
Junquito89
09-27-2015 10:22 PM
Bruce2
09-27-2015 08:45 PM
