Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-17-2004   #1 (permalink)
l3lackstatic
Senior Member
l3lackstatic's Avatar
l3lackstatic is an unknown quantity at this point
Send a message via AIM to l3lackstatic Send a message via Yahoo to l3lackstatic
Exclamation Wheel Hub Help IM STUCK!!!!
Aight guys I took off my right front rotor so that i could take off my busted stud and my stripped stud :hit head:. heres the probelm the slide hammer with the hub adapater goes on like this; X bein where I should bolt em down
O X
x O
But the stud thats stripped and the other thats broke are on the same side; the S bein the Stripped and B bein the broken.
O O
S B
Ive been tryin to use the slide hammer to get it out but its not gonna pull it evenly on the studs, which is why i think its not comming out.
I really dont want to call a tow truck and take it to a shop, because Im so close to bein finished. So if any of you guys have any recomendations on how to get the hub off like tips or anything. It would be much apreciated. Untill then MY civic stays in the garage. Help Me please with any advice. Thank you
l3lackstatic is offline   Reply With Quote
Sponsored Links
Old 07-17-2004   #2 (permalink)
streetglower
7thGen Junkie
streetglower's Avatar
streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all streetglower is a name known to all
Send a message via AIM to streetglower
you need a hub presser I think it is called to get the hub off.
streetglower is offline   Reply With Quote
Old 07-20-2004   #3 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Quote:
I've RARELY have to pull the hub to install studs on a civic. Im not sure about our 7th gens thou. Usually you can slide the stud in with some care by either bending the tin shield out of the way, or being creative with a die grinder. If the hub MUST be removed do it with great care and be sure to re-torque the axle nut. If you cant remove the hub with the slide hammer you may have to remove the knuckle and take it to a press, or if you know of a shop that has a tool called a hub-shark it too can remove the hub while the knuckle is on the car
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans! Now 10psi no dyno yet!
Click Image for my turbo install!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Tags
2001 , axle , cant , civic , hammer , honda , hub , remove , removing , replacement , slide , stripped , stuck , stud , threads , wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Falken Ziex Ze-912's or Kumho Ecsta ASX?
Online Wheel Stores & Manufacturers
Black Rims, Red Lip
DIY: Brake Pads and Rotor Install *Updated*
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
