Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-15-2004   #1 (permalink)
zen_master
Ultimate Member
zen_master's Avatar
Send a message via AIM to zen_master Send a message via MSN to zen_master
Arrow HELP ASAP: replacing brake shoes....
hi guys!!
i'm planning to change my rear shoes for my drum.....now, i wanna change it because the "pulling/stretching" noises that comes from the drums when i pushed my brake while idling..
my questions:
1. does the rear brake actually brake the car when ur braking while moving? or is it only for hand braking?
2. what might be the possible causes for the "pulling/stretching" noises? the cables? the springs? pins?
3. when i change my rear shoes, do i need to replace any of the rear brake hardware (springs, pins, etc)?
I heard that there's a "rear axle brake kit" that you can use while fixing ur rear brakes....
thanx for your help!! i really need ur help now! =)
__________________
2003 Civic EX Sedan
zen_master is offline   Reply With Quote
Sponsored Links
Old 06-15-2004   #2 (permalink)
dj02
Post Master General
dj02's Avatar
dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all dj02 is a name known to all
Send a message via AIM to dj02
1. brakes when u break, just not as hard as the front.
2. the break pads
3. no unsless u damged something back there.
__________________
-OuTuViT-
"Computer games don't affect kids,
I mean if Pac-Man affected us as kids,
we'd all be running around in darkened rooms,
munching magic pills and listening to repetitive electronic music."
-Kristian Wilson, Nintendo, Inc, 1989
it has been said that sometimes,
something as small as the flutter of a butterflys wing
can ultimatly cause a typoon
half way around the world
-chaos theory
The Edge... there is no honest way to explain it
because the only people who really know where it is
are the ones who have gone over.
-Hunter S. Thompson
dj02 is offline   Reply With Quote
Old 06-15-2004   #3 (permalink)
zen_master
Ultimate Member
zen_master's Avatar
2. u mean the shoes? i hope so....i bought a new set....hopefully it will kill the noises..
3. in general, which part usually breaks?
__________________
2003 Civic EX Sedan
Old 06-15-2004   #4 (permalink)
dru106
ThE CoRRupToR
dru106's Avatar
dru106 is just really nice dru106 is just really nice dru106 is just really nice dru106 is just really nice dru106 is just really nice
Send a message via AIM to dru106
Make sure u put grease on the backing plate
__________________
Stock!!!!
dru106 is offline   Reply With Quote
Old 06-15-2004   #5 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Quote:
only on the shoe contact points and VERY little is needed
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Old 06-15-2004   #6 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
Quote:
Originally Posted by zen_master
hi guys!!
its recomended to replace everytime you change the shoes but not always needed. it will help the brake shoes return and stay in the rest posistion. Think of it this way, brakes make heat, LOTS of heat. Springs change temper with heat....... replace springs
__________________
Or
DIY Head gasket
Old 06-16-2004   #7 (permalink)
zen_master
Ultimate Member
zen_master's Avatar
icicicic..
so, grease on the backing plate? hm....that's on the metal part of the shoes, right? not on the pad, right?
__________________
2003 Civic EX Sedan
Old 06-16-2004   #8 (permalink)
flotsamm
Ultimate Member
flotsamm's Avatar
flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold flotsamm is a splendid one to behold
Yes, where the shoes contact the back plate put a tiny amount of grease so the shoes can move back and forth easily. Never put grease on the pad part of the shoes.
flotsamm is offline   Reply With Quote
Old 06-16-2004   #9 (permalink)
EM2Civic
Senior Member
EM2Civic's Avatar
EM2Civic is an unknown quantity at this point
u got the shoes yet?I have a set, brand new, $30 plus shipping!
EM2Civic is offline   Reply With Quote
Old 06-17-2004   #10 (permalink)
Aohan815
Member
Aohan815's Avatar
Aohan815 is an unknown quantity at this point
dude im having the same damn problems cept my back brakes go squeak squeak everytime i let go of the pedal....i was gonna do the rear disc conversion but hondaluver caught a mistake i didnt....i was about to buy the 2004 si rears....4 lug in the front and 5 lug in the rear...LOL....YEA!!!!
Aohan815 is offline   Reply With Quote
Old 06-17-2004   #11 (permalink)
zen_master
Ultimate Member
zen_master's Avatar
heheheheheheh
cool!
anyway, i already got the pads....raybestor premium pad......yeah, whatever...i don't need oem for rear pad...
im gonna get aem nissin for front, hehe =)
__________________
2003 Civic EX Sedan
Old 06-18-2004   #12 (permalink)
Aohan815
Member
Aohan815's Avatar
turns out it wasnt the shoes just all that rust and dust in there....cleaned it out and the noise and grinding feeling is gone!
Old 06-18-2004   #13 (permalink)
zen_master
Ultimate Member
zen_master's Avatar
yay....
well2, i'll just change it anyway tomorrow.....ha ha ha
cos im gonna pay my mechanic to do that....so, it's better to keep him busy for 1 hour......cos' that the hourly labor rate...for him..
__________________
2003 Civic EX Sedan
Old 10-12-2009   #14 (permalink)
seoul4korea
Member
seoul4korea is an unknown quantity at this point
Re: HELP ASAP: replacing brake shoes....
DIY Drum Brake Shoe Replacement
This was the first post
seoul4korea is offline   Reply With Quote
Tags
2003 , 2006 , 90 , 94 , brake , change , civic , drum , dx , install , pads , rear , replace , shoe , shoes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
