| All the EP components should interchange. Any full coilover will interchange. Any fixed height system will NOT cross over. EP stuff is EP stuff and won't work right in the EM/ES. 03 and on have larger front crash bolts as well. Since the EU is just an EP with back doors, I would say that EP stuff goes right in... an ES is really just an EM with back doors (or visa versa). The hatch has shorter rear stuff than the coupe/sedan and longer fronts. With an adjustable system, you can work it all out, but if its fixed height, you can't. |
