Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-09-2004   #1 (permalink)
iLLuMiNaTi
Senior Member
iLLuMiNaTi's Avatar
iLLuMiNaTi is an unknown quantity at this point
Send a message via AIM to iLLuMiNaTi
brakes/noob question
Hey
my brakes are screaching and when im going above 60 and i need to come to a "quicker than usual" stop or have to slow down a lot quickly, i feel the ABS kick-in (at least i think it's the abs; i feel a quickly repeating braking pattern (don't really know how to describe it)). anyways, do I just need to replace my brake pads? or do I have to do more..?
thanks in advance
Axel
__________________
Proud SoundSplinter RL-p12 owner.
Two of these will own your honda:
vid of Djdilliodon's 2 SS RL-p12's sealed, powered by PG MS1000 TA
iLLuMiNaTi is offline   Reply With Quote
Sponsored Links
Old 02-09-2004   #2 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
ABS kicks in any time the system senses one of the tires is decelerating quicker then the other tires (Possibly locking up) so to cure that get stickyer tires. as far as screaching, thats mostlikly pads. check the wear level on them they may be in need of replacement.
for pads, depends on what your budget is and what performance you want out of them.
Cheepie... OEM (Satisfide Pro Preformance OEM), or other equivelant. should run about $30
More Expensive but better performance, Ceramic Kevlar (AEM/Nissin)(Akebono ProACT)(Satisfied Pro Ceramic) Full sets of pads shoud run about $50
Better perfromance but more expensive Basic Composit brakes (Carbon Kevlar or Carbon Metalic) EBC Greenstuff or Hawk HPS Street would do well. cost about $60
Top end, not nessisailry better braking then the previous, but Much higher heat resistance.
EBC Redstuff, Hawk HP Plus Race pads, Porterfield R4-S or R4 compounds Cost $70+
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Old 02-09-2004   #3 (permalink)
iLLuMiNaTi
Senior Member
iLLuMiNaTi's Avatar
hmm.. just found out that my brother didn't get my tires aligned when he changed them for me (i was out of town), could me getting them aligned help at all with the ABS thing?
Old 02-09-2004   #4 (permalink)
tfnaaf
BLDNPSI Mod
tfnaaf's Avatar
tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned tfnaaf should not be questioned
Quote:
Not unless the alignment was so far out that it was causing traction issues. If it were out that far then you would have SEVER handling problems!
__________________
169.8whp / 154 ft lbs tq @ 7psi with an auto trans!
Click Image for my turbo install!
Or
Check out my 1966 OLDS 442 Project in the works!
DIY Mechanical O2 simulator
DIY Head gasket
DIY Front Wheel Bearing
How to tune short term/long term fuel trim
tfnaaf is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
