Wheels,Tires & BrakesPost Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
Im sorry but i just have to vent about what people think they can do with their brakes.
Every other day somebody posts how to do the rear disc brakes. People just do not search, it makes me so mad.
here are some facts about our brakes.
1. to do a rear disc brake conversion you need from ONLY a US 02-03 si: 1. calipers 2. discs 3. spindles(knuckel) 4. e-brake cables from a rsx or si 5. dust covers. (picture below)
2. You cannot move the front rotors to the back.
3. The front si brakes are the same as our front
4. Stop asking what is needed, i already posted everything
5. The rear disc swap is straight up, no cutting what so ever
6. If i just had brakes on a non-ex, I would first upgrade my cars tires, then add a ABS system, then disc pads, then rear discs. With this you will never even need to upgrade ur rotors, unless you just wanna look cool, the bigger calipers will problem make u lose your braking ability.
Currently I have Parada spec 2 tires with 215/40/18(23.5 pounds each) rubber on centerline rims 18x7(14.5 pounds each), a total of 38 pounds, 2 pounds lighter than stock rims and tires.
I have ABS(ainti-lock brakes system) which has saved me from a million accidents and does not make my rims lock up, which would lead me into a uncontrolled slide. I have rear disc brakes from a si. and i have AEM pads all around. i have slammed on my brakes and i have stopped as soon as i needed them. i think i might even compete with a porche in braking. Remember the 2 main things that will stop you are pads and tires; abs will just help the situation. these little mods are the only things i think any civic owner needs. no big brakes are going to ever going to be needed, well unless you wanna look cool. o yea, ventilation to ur calipers will help not over heating ur pads which is what most big brakes claims to stop... which can be easily solved by getting bigger rims that have good ventilation.
if i had to chose what i would do to my car it would be get 16's with some Azenis, and better brake pads... that would be all i would ever need
I will answer no more questions about what is needed for rear brakes ever again.
__________________ 01 SSM em2 k24 hybrid
06 Red CBR600RR
Status:
01 SSM em2 built k24bar'd NA tune(till turbo time)...240.7 hp and 190.9 tq
^^^^^^ Cool you got seperate weights! As i recall mine are right about that same weight total! @ you big wheel haters!
__________________ 169.8whp / 154 ft lbs tq @ 7psi with an auto trans! Now 10psi no dyno yet! Click Image for my turbo install!
i got all my parts used from a 2002 si for 500 bucks, for me it was 350 bucks but i needed to get a new spindel for one side(150), since it was bent from the accedent it was in
06 Red CBR600RR
Status:
well why don't you write up a Rear Disk Conversion FAQ and we can add it to the rest! Hopefully they will see that, but I doubt it. Just laziness on their part.
__________________ Life isnt a test drive, gotta live a little. (02fpcivic)
i'll probly do one later on.. try to gather up all the questions that people have been asking.. but for now, this is the thread to look to for rear discso ur lockings will be easier...
thanx
06 Red CBR600RR
Status:
Originally posted by HondaLuver i got all my parts used from a 2002 si for 500 bucks
im guessing labor will cost u like 100-150(matters where you take it to) bucks cause it takes along time... the bleeding, and making sure everything fits, the endlinks that are a bastord and i really suggest a torque wrench... oyea and if you do this, i reccomend you use a lift cause the brake lines have to be disconnected from inside where the ebrake is and run the lines under the car, you have to move the brackets down a tiny bit, the brake lines will fit kinda tight, but the will fit.
i think this was really worth every penny i spent on it...
06 Red CBR600RR
Status:
you need the abs modual, and run all the lines. im not sure about about running the abs sensors. i think that the stock breaks should have the sensor inputs but no sensors running to them.
06 Red CBR600RR
Status:
Im going to be doing this conversion next month. Heres a complete list of honda part numbers and there prices from majestic honda (hondaautomotiveparts.com).
1073309 007 1 CALIPER SUB-ASSY., R. RR. 154.51
1073310 008 1 CALIPER SUB-ASSY., L. RR. 154.51
1082874 006 2 DISK, RR. BRAKE 35.66
1095008 028 1 MUDGUARD, R. RR. 15.83
1095009 029 1 MUDGUARD, L. RR. 15.83
1073334 001 1 KNUCKLE, R. RR. 143.28
1073335 002 1 KNUCKLE, L. RR. 143.28
1095011 005 1 WIRE B, R. PARKING BRAKE 25.54
1095012 008 1 WIRE B, L. PARKING BRAKE 24.08
DAAAMN! pricey mod! Does it really help though (rear disks)? I read in an old thread it doesnt help much! Also, for non abs cars, doing this will enable ABS? Thanks!
this is a really good mod, it helps the braking alot. this is pricy but i rather pay 600-700 now to save about 5,000 in damages from a accedent that i could totally avoid in the future. no this will noto enable the abs. you will need to get the whole abs system that only comes on EX civics
06 Red CBR600RR
Status:
Here in Canada we can purchase an Acura EL that has all of this as stock equipment plus more. We enjoy it. Alot! And for about the same price as a Honda EX 4 door.
