Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 11-18-2003   #1 (permalink)
CvC-v01
Super Member
CvC-v01's Avatar
CvC-v01 has a little shameless behaviour in the past
Arrow how do i change the back brakes
hello!!! i wan't know if someone can help me change my back brakes...
if u can step by step
CvC-v01 is offline   Reply With Quote
Sponsored Links
Old 11-18-2003   #2 (permalink)
mig
Senior Member
mig's Avatar
mig is an unknown quantity at this point
Found this by searching:
"remove the wheel,hub cap(in center) with a flathead,raise the stake and remove the spindle nut,screw two 8x1.25 mm bolts into the drum to push it away from the hub,turn each bolts 2 turns at a time to prevent cocking the drum excessively,remove the drum and hub bearings unit from the spindle.next question?
ok, here is the rest.. remove the tension pins by pushin each retainer spring and turnin the pins,,remove the lower return spring and remove the shoe assembly over the hub,, remove the upper return spring and disassemble the brake shoes,disconnect the parking brake lever and remove the shoes..remove the U clip.wave washer and pivot pin and seperate the parkin brake lever from the shoe and thats it!!!!!"
I'm doing mine this weekend, plus I'm also installing stainless steel brake lines. good luck
mig is offline   Reply With Quote
Old 11-18-2003   #3 (permalink)
CvC-v01
Super Member
CvC-v01's Avatar
thanx...."mig" if u get any more info keep me posted...thanx once again
Old 11-18-2003   #4 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned Zzyzx should not be questioned
Quote:
where did you get your brake lines?
__________________
Las Vegas SCCA
Autocross: Because Life is more fun on three wheels......
"I know Solo only comes one minute at a time, but what an intense, non-stop, fast-forward car control exercise minute it is. Sure, the velocity is higher in road racing, but inside the car it is slow-motion in comparison. In Solo, the turns come like machine-gun rounds. "
Randy Pobst
Zzyzx is offline   Reply With Quote
Old 11-18-2003   #5 (permalink)
mig
Senior Member
mig's Avatar
www.competitionwarehouseusa.com
Ask for Carlos. These are the Russel SS brake lines, and they were $80 shipped. Their quality is impressive.
Also got Speedbleeders, Brembo rotors, Porterfield RS-4 pads and shoes, and ATE Super Blue brake fluid. Looking forward to better stopping and brake feel.
Old 11-18-2003   #6 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
That is exactly what I am going to run........ Who are you and why are you reading my mind?
got the rotors last week and the Porterfields should show up this week.
I'm setting up the brakes for autocross and Track days.
For brake fluid I was originally thinking Motoul 600, but Was detered by its water absrobtion rate. the ATE super Blue just looked to be the best for dry and wet boiling points and resistance to water absorbtion.
__________________
Las Vegas SCCA
Randy Pobst
Old 11-18-2003   #7 (permalink)
mig
Senior Member
mig's Avatar
are you doing your own install? one of the things I'm unsure of is what should I being doing with regard to the bleed out of the line while I'm installing the new brake lines. will all the old fluid try run out and should I be monitoring the master cylinder resevoir? concerned about too much air getting into the system.
Old 11-18-2003   #8 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
you're probably going to have to drain the whole system.
I'm just doing the Rotors pads and shoes this weekend (I'm debating if I shoud get some new Drums) I was going to change the fluid and lines durring our regions off season (dec-Jan), and I havent decided if I want to do that my self, or pay some one.
Old 11-18-2003   #9 (permalink)
mig
Senior Member
mig's Avatar
i could not find any non-OEM drums. let me know what you come up with.
Old 11-18-2003   #10 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
I was thinking OEM, but at $70 each I dont know if its worth it.
Old 11-18-2003   #11 (permalink)
HondaLuver
Its a celebration bitches!
HondaLuver's Avatar
Send a message via AIM to HondaLuver
how much better would stainless steel brake lines help me?
i need some for my front and rear disc brakes.... i'll just get some 02 si ones...
__________________
01 SSM em2 k24 hybrid
06 Red CBR600RR
Status:
01 SSM em2 built k24bar'd NA tune(till turbo time)...240.7 hp and 190.9 tq
Stuff for sale
HondaLuver is offline   Reply With Quote
Old 11-18-2003   #12 (permalink)
Zzyzx
Autocross Junky
Zzyzx's Avatar
its more of a safty issue rather then an increase in performance.
If our cars were old and the OEM brake lines were weak then youd get some improvemtent.
at most you would get a more positive feel of what the brakes are doing.
Old 11-18-2003   #13 (permalink)
CvC-v01
Super Member
CvC-v01's Avatar
SORRY...I MEANT TO SAY BACK DRUMS.....
Old 11-18-2003   #14 (permalink)
HondaLuver
HondaLuver's Avatar
__________________
06 Red CBR600RR
Status:
Stuff for sale
Old 11-18-2003   #15 (permalink)
djmota
djmota's Avatar
djmota is just really nice djmota is just really nice djmota is just really nice djmota is just really nice
hey Zzyzx, did you get your porterfield shoes and pads direct from them or a reseller?
How much where the rear shoes?
__________________
133.48 whp 117.57 tq all motor untuned dynojet
188.87 whp 187.99 tq 75 shot n20 untuned dynojet
147.5 hhp 130.5 htq all mtr tuned church's dynapack
my old d17 set up.
now swapped k20a2 4.7fd lsd kpro
djmota is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Online Wheel Stores & Manufacturers
Falken Ziex Ze-912's or Kumho Ecsta ASX?
DIY: Brake Pads and Rotor Install *Updated*
Black Rims, Red Lip
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
