Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Wheels,Tires & Brakes
Wheels,Tires & Brakes Post Wheel, Tire & Brake related modification information and/or questions here.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 07-07-2003   #1 (permalink)
ASIANPRIDE
GODLIKE
ASIANPRIDE's Avatar
ASIANPRIDE is an unknown quantity at this point
Broke my lug bolt......
Well I broke my lug bolt 1 of the 4...and well I bought the part....but Honda says it could be 85-170$ to fix...like wtf is that......man..have any of you replace a full rotar how hard is it to take it all apart...and to I have to worry about the hub separating? To remove this ad, register today for free or log in if already registered!
ASIANPRIDE is offline   Reply With Quote
Sponsored Links
Old 07-09-2003   #2 (permalink)
ASIANPRIDE
GODLIKE
ASIANPRIDE's Avatar
Bump....
Old 07-11-2003   #3 (permalink)
blustrek01
Member
blustrek01 is an unknown quantity at this point
to replace the broken stud the dealer has to pull the hub off. had the same problem and tried to make the repair myself. unfortunatly that is the only way to fix it. good luck
blustrek01 is offline   Reply With Quote
Old 07-25-2003   #4 (permalink)
ddongs
Member
ddongs's Avatar
ddongs is an unknown quantity at this point
which one did you brake?? front? or rear??
the same problem just happened today..
ddongs is offline   Reply With Quote
Old 07-26-2003   #5 (permalink)
IDQcivic
Diamond Member
IDQcivic's Avatar
IDQcivic should not be trusted
lug nuts should be torqued to 80 ft-lbs, dont overtighten them!!!
IDQcivic is offline   Reply With Quote
Old 07-28-2003   #6 (permalink)
Grey
DIY King
Grey's Avatar
Grey has a spectacular aura about Grey has a spectacular aura about
Send a message via AIM to Grey
You have to get the hub off. That means you need to take the front rotors off, or the rear drum off. Then untorque that huge nut holding the hub on. You'll need a breaker bar for that since it's on there at like 100+ foot pounds. Don't know the exact torque. Then you have to pound the old lug bolt out and pound the new one in. Then re-assemble everything. That hub bolt has to be on there tight too and the torque for that sucker has to be pretty close to what it was at. Any less and you get loosening. Any more and you get more stree and possible fracturing. Just like the lug bolts. Torque is very important. Metals expand, but they can't expand forever. They eventually break.
Grey is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
OFFICIAL rim picture galley, post up
DIY Drum Brake Shoe Replacement
Drums--->Discs SPELLED OUT
Falken Ziex Ze-912's or Kumho Ecsta ASX?
Online Wheel Stores & Manufacturers
Black Rims, Red Lip
DIY: Brake Pads and Rotor Install *Updated*
Wheels, Tires and Brakes FAQ
BIG ASS RIMS ON THIS CAR---->
7th Gen Civic's TIRE REVIEW THREAD
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
