Go Back   Honda Civic Forum > Honda Civics by Generation > Honda Civic Si and Honda Civic SiR
Honda Civic Si and Honda Civic SiR The Honda Civic Sport Package, better known as the Honda Civic Si is a great base vehicle to start a project. Upgraded components on the Honda Civic Si gave this car a advantage from the start. The Honda Civic SiR is the Canadian version for the Si.
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-03-2003   #1 (permalink)
solar
Diamond Member
solar's Avatar
solar is an unknown quantity at this point
03 Si oil capacity has me confused
In the manual is shows that the engine holds 5.6 quarts of oil, but when you do a oil change with filter is only requires 4.4 quarts of oil. So theres 1.2 quarts of old oil in the engine when you do the oil change? Does anyone know the answer to this? I'd call the dealer but I'm sure they wouldn't know or just give me some BS. To remove this ad, register today for free or log in if already registered!
solar is offline   Reply With Quote
Sponsored Links
Old 06-06-2003   #2 (permalink)
AlexLx
Member
AlexLx is an unknown quantity at this point
Send a message via AIM to AlexLx
for some reason I think the 4.4 is a misprint in the manual. It should probably be more like 5.4 Q. If i put 4.4 in there it's at the bottom circle on the dipstick. I just disregard the manual on this and put in however much oil it takes to register on the dipstick.
__________________
i don't drive an lx anymore, but im still part of the honda family. ep rules.
AlexLx is offline   Reply With Quote
Old 06-06-2003   #3 (permalink)
solar
Diamond Member
solar's Avatar
Quote:
Thats good to know, thanks, but I can see it being misprinted in the manual, but its also on the Honda Website
Old 07-12-2003   #4 (permalink)
SinisterCivicSi
Member
SinisterCivicSi is an unknown quantity at this point
Send a message via AIM to SinisterCivicSi Send a message via Yahoo to SinisterCivicSi
the dealer told me it holds 4.4qts....i have an 02 but it should hold the same. but if your goin by your dipstick, then thats the best way i guess.
SinisterCivicSi is offline   Reply With Quote
Old 03-21-2009   #5 (permalink)
normaltype
New Member
normaltype is an unknown quantity at this point
Re: 03 Si oil capacity has me confused
That may be a factory spec. When you do an oil change you never get all of the oil out....some oil is left in the block.
So at the factory when they put oil in it for the first time it may have taken 5.6 quarts. But your right, 1.2 quarts sounds a little too much. U never know though.
I've seen some manufacturers in the past use factory specs in owners manuals....can make things confusing.
normaltype is offline   Reply With Quote
Tags
03 , 05 , 18 , 2003 , 2006 , 2009 , capacty , capisity , civic , honda , oil , put , quantity , quarts , si , wrong
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Links to other '02 Si/SiR sites...
1/4 mile times! add yours!!!
Lets see those hot si's!!!
For All Si Owners!
Armrest for '03 Si?????
Chicago preview of 06 Civic Si
Heres my SI(MANY PICS)
Question on wide body kit for SI.
'04 si bolt pattern
i-vtec controller...
Site Supporters
aluminum radiator
Honda car spoilers
