| Re: 2000 Honda Civic Si P0122 and P0505 error try to clean the idle air valve again and see if it helps. could also be the fast idle thermo valve if you have one. for the tps problem, you need a whole new throttle body, usually the tps cannot be replaced easily, and it needs to be calibrated. it costs more than getting a used tb on ebay for $50. make sure you get the right throttle body for auto or manual trans. and get new gaskets if they are old.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring. |
