Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-30-2007   #121 (permalink)
sto73
New Member
sto73 is an unknown quantity at this point
Re: Your answer may be here! TSB / Honda Complaint Address / Etc...
whats the best way to check a wheel bearing? To remove this ad, register today for free or log in if already registered!
sto73 is offline   Reply With Quote
Sponsored Links
Old 12-30-2007   #122 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
wheel bearing will grind when the wheel is spun, its not likely that that is whats wrong, only way i can tell u to check it is to lift the front of the car, put into neutral, and spin each wheel, listening to the bearing, if it grinds, replace it, if not, its not the bearing
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 12-30-2007   #123 (permalink)
RHCP0801
RHCP0801's Avatar
RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute RHCP0801 has a reputation beyond repute
it wont always grind if the wheel bearing has gone bad, actually i have never heard of one grinding
jack up your car and grab the top and bottom of the wheel and move it up and down, if the wheel has a lot of play in it than the bearing is shot and needs to be replaced
__________________
RHCP0801 is offline   Reply With Quote
Old 12-31-2007   #124 (permalink)
sto73
New Member
thanks alot everyone. does anyone else have the popping noise when they turn at low speed?
Old 01-28-2008   #125 (permalink)
civicrida15
New Member
civicrida15's Avatar
civicrida15 is an unknown quantity at this point
everytime i wash my car i have to wait a couple days before i put my windows down because water gets on the inside of my windows when i roll them down and roll them back up and my freaking car rattles like crazy when i go over bumps and im riding on stock suspension...i have window rattles and i think the sunroof rattles too
civicrida15 is offline   Reply With Quote
Tags
06 , 2003 , 2007 , 2nd , 99029 , american , bulletin , civic , complaints , gear , honda , list , service , si , tsb
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
