Mechanical Problems/Vehicle Issues and Fix-it ForumIf you've got a problem you just can't figure out, a noise you can't diagnose, or a Check Engine Light that won't go away, ask about it here!
Welcome to civicforums.com!
Welcome to civicforums.com.
When i crank my car up in the morning, 01 ex, it starts up fine but when it starts to warm up it idles real rough like your in a 454 or something for a few seconds then its fine. Can someone tell me why it would be doing that???
Sponsored Links
The brand of oil shouldnt make much of a difference and as long as its the right viscosity. Could be that your TPS(trottle position sensor) is marginal, or even your CTS(coolant temp sensor). I've even read that it could be your ECU code needs to be updated. Have you tried resetting the ECU? Disconnect your negative battery cable for a few minutes and reconnect it. Right down your radio stations if you care. There's a section in the owners manual that tells you how to properly do this so your ECU re-learns your driving style. Mayb not fixe it, but worth a try.
All you guys probably have 2001 civics. I heard that ECU unit is messed up on some of them. My advice, if the car does not shut down, keep on driving, if it does - take it to the dealer and the first words out of your mouth should be WTF!
Good luck
