Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-14-2002   #1 (permalink)
Silversleeper
Platinum Member
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
Send a message via ICQ to Silversleeper Send a message via AIM to Silversleeper
clutch problem
lately ive noticed that when, from a stop, i begin to move in first gear, while releasing the clutch the idle tends to wana drop dramatically. the clutch engages/disengages farther away from the ground than it used to. and when its just about to release, it seems like it wants to stall the motor. i have to rev more to keep everything smooth. this really becomes a problem going uphill. i fear my clutch will need replacement soon. i only have about 9500 miles. i dont race much, havent even been to the track yet. has the clutch self-adjusted itself or something? need some opinions. To remove this ad, register today for free or log in if already registered!
Silversleeper is offline   Reply With Quote
Sponsored Links
Old 10-15-2002   #2 (permalink)
solar
Diamond Member
solar's Avatar
solar is an unknown quantity at this point
Do you give it a little gas as you let out the clutch, or do you just slowly let the clutch out and then give the gas? Your problem you mentioned with the clutch engaging farther from the floor than it used to is normal. Everyone I've talk to on this site mentioned the same thing. There is no adjustment on the clutch itself, the only adjustment is the clutch pedal height but it won't change the performance of your clutch. I also have 10,000 miles on my car, and the clutch is the same way.
solar is offline   Reply With Quote
Tags
clutch , hight
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
