! my radio stays on when i turn off my car
Old 08-24-2002
MOUSE's Avatar
MOUSE is an unknown quantity at this point
my radio stays on when i turn off my car why is that
Old 08-24-2002
solar's Avatar
solar is an unknown quantity at this point
Really? Is it the stock radio? Have you done any upgrades to the sound system?
If not and you're under warrenty take it to the Dealer.
Old 08-24-2002
DaCurryman's Avatar
DaCurryman is an unknown quantity at this point
Sounds like my problem, except for me it's my headlight that wont turn off. Anyways, if it the factory one, just take it back and let them fix it under warranty.
Old 08-24-2002
civicjunkey's Avatar
civicjunkey is an unknown quantity at this point
that same thing happened to me when i got my aftermarket CD player put in, so i pulled it out right before i went to work, because i didn't want a dead as civic waiting for me when i got off, and i followed the wires around and couldn't find anything, then i was like WTF, so luckily i got off work early that day at took it to where it was installed, yeah I know if figures, and they tinkered with it alittle and after about 15 mins they came back and said that some wires were touching or something, so factory or aftermarket.... take that $hit back
Old 08-26-2002
beamer's Avatar
beamer is an unknown quantity at this point
I'm going to guess you installed a new cd player. test the wires with a 12 volt tester find out witch one is hot all the time and witch one turns on and off with the car, match them up with you're cd player. if you're head lights stay on then you have you're dimmer tied in. If you need I can tell you tomorrow the color.
Old 09-10-2002
1hot01civic's Avatar
1hot01civic is an unknown quantity at this point
Quote
[hr]Originally posted by: beamer
I'm going to guess you installed a new cd player. test the wires with a 12 volt tester find out witch one is hot all the time and witch one turns on and off with the car, match them up with you're cd player. if you're head lights stay on then you have you're dimmer tied in. If you need I can tell you tomorrow the color.[hr]
sounds like you wiring is mixed up if you have an aftermarket cd player
Old 09-10-2002
7thgen guh chee
JohnnyLee's Avatar
Gotta be the wiring
Old 09-11-2002
Oishi's Avatar
Oishi is an unknown quantity at this point
yep wiring...both the accessory and constant +12v wires are connected somehow...
Old 04-02-2015
lildoo's Avatar
lildoo is an unknown quantity at this point
Re: ! my radio stays on when i turn off my car
Remote wire is staying on... I usually put them under a blower motor fuse as they only work when the key is engaged
mikemc422
08-09-2018 05:41 PM
gearbox
Electrical DIY
72
11-27-2015 08:13 PM
TheCrimsonKing
Engine start problems
04-25-2015 09:40 PM
Ian SFBA
Interior DIY
04-25-2015 02:25 PM
GH04si
04-15-2015 08:13 PM
Quick Reply: ! my radio stays on when i turn off my car
