Rod Knock?
Rep Power: 0 Rod Knock?
02 Ex Automatic. I've got a noise coming from my engine. It sounds like a knocking when the car is idling in gear. It is audible in park but not so loud. As I come to a full stop the noise progressively gets louder. When the car is accelerating it sounds like a buzzing and then it is usually not audible when driving steady at low RPMS. It seems like it is better when the engine is cold and progressively worse as it gets hotter. I read somewhere that you could confirm it was rod knock by disconnecting the ignition coils one at a time and one would make it quieter. But disconnecting each coil seems to make it much louder.
I've already made peace with the fact that it is a spun bearing and that it is too far gone. But is there any reason to think that it isn't rod knock? Is there any way I can confirm it without pulling the pan?
Thanks
Thanks
Re: Rod Knock?
Has it been run out of oil? Oil changes neglected?
Use a stethoscope to determine a source area or pinpoint it?
Spring is missing from the timing belt tensioner pulley?
Has the trans ever been removed?
Rep Power: 0 Re: Rod Knock?
The noise has gotten progressively more frequent. At first it kind of just seemed like a random one off thing but now its every time after about 5min of driving.
Re: Rod Knock?
Wooden dowel or long screwdriver (or just about anything similar) held to your ear can work as a stethoscope.
Your first post doesn't make me think bearings.
I really want to say........Go under and recheck the 8 small torque converter-to-flexplate bolts.
Just curious, what makes you think not bearings?
Hmmm... I'll check. I really thought I did a good job on those. Worked out the star pattern and even did 2 steps with a beam wrench to 9lbf.
I'll take drop the exhaust and take a look at that tomorrow. Any other potential ideas?
Re: Rod Knock?
(I can't see what you are dealing with from here)
Drop exhaust? Can't the inspection covers come off just enough to check the bolts without taking apart the kitchen sink?
You are a genius though. I'll upload a picture later but basically one of the 8 had backed itself out and had flattened itself on the cover plate. I'm going to go check homedepot for a bolt.
How do I keep them from backing out? I'm sure I torqued them all to 8.7lbf like it asked for. Should I go a little tighter?
Re: Rod Knock?
Maybe you just completely missed tightening that one bolt?
Inaccurate torque wrench?
If that were the case I'd suspect some or all the rest of the bolts could be on the verge of coming loose too.
I tighten those by hand myself.
If I were torquing, I'd have used an inch-pound torque wrench for that low value.
Loctite....low strength threadlocker?
take a good one for an example.... If it's not an exact match, you may want to get a pair and you can place them 180* apart to keep the rotating mass in correct balance.
Re: Rod Knock?
This the right stuff?
LOL
Yea loctite 242 is ok IMO.
Price sounds high, glad the shop pays for this stuff LOL
I don't use it on TC bolts though, I think you just didn't get them tight enough.
Posting so I can hopefully find this video later LOL
This is what it looked like. That bolt is a couple mm shorter than it should be. New bolts in and the car runs great. It's amazing what a difference actually having the transmission attached can do.
Re: Rod Knock?
OH OH OH A BLUE CONVERTER! LMAO!
Did you tap out the holes (chase the threads) before assembling? They may have had paint in them causing your problem.
Last damn blue converter I saw was in a Jasper reman trans (long story, twice) and all of the converter bolt holes had to be tapped by hand before any bolts could be threaded into it.
This one was Pro King, I got it from Oreilly. I didn't know anything about how to juge a converter so I just went with what was available at the time. The bolts were definitely hard to get started the first time but I managed to get them in. Never thought to tap them. The new bolts went in better this time around so maybe they will hold. I was planning to check them again this weekend anyway.
