03 LX - Lost Lowbeams, tried a few things, stumped
Rep Power: 0 03 LX - Lost Lowbeams, tried a few things, stumped
Hey guys, I'm hoping you can help a poor college student out.
About a week ago I randomly lost my lowbeams. Highbeams still work, as does everything else. I checked the headlight fuses, they are fine. Swapped the relays to see if it was the headlight relay, no change. Popped a bulb out and visually confirmed it wasnt burned out. Took a voltmeter to the bulb and it showed no open circuits, just to be sure. Figured it was the switch as that's what I've been reading.
Got the switch, swapped it, no good. After swapping the switch, tried swapping the relay again and no go. Figured since I had the voltmeter out I'd take it to the plug to see what kind of voltages I had. With highbeams on Left to top showed 12.5v, top to right showed nada. With lowbeams on, left to top, and top to right showed 0. Also with lowbeams left to right showed 0.
So it looks like I'm not getting power to the plug. My understanding is that power flows from battery to relay to headlight to dimmer switch and then grounds. I hear the relay click when I try to turn the lowbeams on, and I just swapped the dimmer switch. This tells me the break is somewhere between the relay and headlights?
I don't know if thats correct, and if so where to even start looking for the problem. It seems like a wire got screwed up somewhere and with school I do not have the time to search for hours. Anything to narrow it down to where or what it could be more specifically would be amazing.
Thanks guys
Thanks guys
Re: 03 LX - Lost Lowbeams, tried a few things, stumped
Has the recall been completed that addresses this problem?
Contact your Honda dealership, or check your VIN here:
recalls.honda.com
recalls.honda.com
Rep Power: 0 Re: 03 LX - Lost Lowbeams, tried a few things, stumped
recalls.honda.com
recalls.honda.com
Is there a way to tell its the plug without taking it to the dealer? I'm 1.5 hours away from the closest one and can't afford to be taken for a ride by them. I have a few closer but they are across the border into canada so not sure how that would work.
If I can determine if its the plug then I can go from there as thats probably a little beyond my abilities if the whole thing needs to go. If its not and just a single wire I'd like to repair it myself.
You didn't bother to click the link to HONDA in my previous reply and check your VIN?
If your car needs the recall done, by all means have the dealer get it done.
If the recall has already been completed or does not apply to your car, then diagnose away.
edit: snip
edit: snip
Didnt have the vin handy when I replied, sorry. Looks like it is under recall, though I was never notified. I guess ill call honda customer service. I'm hoping I can go across the border and get the work done in a couple hours, I don't wanna go 2-3x the distance to one in the US. Guess well see.
Really wish it was a little simpler.
Let them know the lights aren't working and it's dangerous.
Before you go to the dealership, call ahead to make them aware your lights don't work so they can make sure a replacement headlight switch is in stock or ordered, just in case it's needed.
It may or may not happen that way though, but one can hope.
I did replace the switch so hopefully one is goodd. Seems like the harness. I'll call tomorrow and see how that works. Thanks!
Make sure you have the VIN on you when you call so they can verify the recall status too.
If you have a Canadian wiring diagram and can do some testing, you might reach a correct answer.....
Low beams are the ONLY lights that don't work?? Parking lights, dash lights, high beams, DRLs all still work?
WHen someone turns on the low beams, does the pair of headlight relays click on (in the engine compartment fusebox)?
If not....
I'd remove the column covers, get to the the light switch connector, (unplug and check for burns), if OK then reconnect it and backprobe the blu/red wire in cavity #7, see if it's grounded while the switch is turned on to the low beam position.
