05 honda civic ex main, rod, and head torque specs??????
Old 10-27-2016
05civicandy's Avatar
05civicandy is an unknown quantity at this point
Please help...... I have put all my money into rebuilding this motor and cant aforf to buy a chilton
Honda powerd andy
Old 10-28-2016
mikey1's Avatar
Re: 05 honda civic ex main, rod, and head torque specs??????
Honda powerd andy
you have spent hundreds of dollars rebuilding an engine and you don't have another 25 bucks for a manual?
Old 10-28-2016
GusBuz's Avatar
GusBuz is a jewel in the roughGusBuz is a jewel in the roughGusBuz is a jewel in the rough
Your local library has free online auto repair like chilton or haynes sometimes alldata for free, all you need is to have a library card and you are good.
Old 10-28-2016
Or search
https://www.civicforums.com/forums/1...pdated-13.html
Old 10-28-2016
Yeah thats right.... I have no more money. I am out of work and go back in a week. And i need to have it running by then. Ty for the replies.
Old 10-28-2016
Did you find what you needed, or do you need more specific info?
Old 10-28-2016
I tried to load it but my phone would load it. I also needed the clocking position on the piston rings. Once i get this information i can carry on. The little money i had left i had to spend on fluids and a ring compressor.
Old 10-28-2016
1.7L engine:
Head bolts 3 steps: 14, 36, 49 ft-lb
rods: 24 ft-lb
main bridge 2 steps: 18, 38 ft-lb
Of course use the typical criss-cross and outward radiating patterns typical of any large engine assembly procedures. (sorry I can't hotlink info)
This looks like fairly typical ring install positions http://mmc-manuals.ru/manuals/pajero...6520000ENG.png
Old 10-29-2016
Ty so much bro! You are awesome.. I jave one more question. Is it different torque specs with a main one peice than a bridge?
Old 10-29-2016
Oh and one more thing.... What is the camshaft torque specs?
Old 10-29-2016
That spec was all I found for the 1.7 engine.
rocker shaft holders/cam journals
8mm bolts 14 ft-lb
6mm bolts 8.7 ft-lb
cam pulley bolt 27 ft-lb
Old 10-31-2016
Alright i got it all together and it keeps reving to 2500 rpm and idling on its own . what does that mean?
Old 10-31-2016
Got fault codes?
Got vacuum leaks?
Coolant full and burped?
Take off the breather lid and stick your fingers over the open port in the side of the throttle housing (IAC valve feed port)....If that brings the RPM way down that would indicate the IAC is open for SOME reason, quite likely to be stuck open from sitting.
If plugging the port does NOT bring the RPM way down look for vacuum leaks.
Old 10-31-2016
How do you burp the coolant?
Old 10-31-2016
See post 2, item 2
https://www.civicforums.com/forums/3...reference.html
Old 11-02-2016
Well o dont know where to begin
..... I figired out it was a vaccum leak. Then the next day its starts running warm. Upon ajusting my valves........ Bam.... I find earl in my cylinder. .... I gies some of the rings moved on me upon insertation. ... Was the a specific place for the expander ring cause i noticed on there it didnt have one????????
Old 11-02-2016
Can u send me the clocking diagram one more time please....��
Old 11-02-2016
And 3 of my pistons are marked 3 and 1 of them is marked 2
... Does that mean anything??? This is my first rebuild...
Old 11-02-2016
Pistons and rods are usually marked in some way for minor size variations, make SURE they return to the holes they originally came out of.
Rings: It's up to you to make sure the rings are installed in the correct places and make sure they are actually right side up according to the manufacturers instructions. Not all rings are the same and if you get any upside down it will cause problems.
I can't see the pics in the previous post either. I'll try my hand at ASCII LOL
You do NOt want any of the gaps to line up on the wrist pin nor thrust areas. You want the gaps about 45 degrees away from the wrist pin line.
Basic ring gap positions:
oil ....... l....... 2nd
............l............
---wrist pin line---
oil.........l............
spacer....l......... oil
and...................
top..................
