2005 civic ex sedan 5 speed check engine light blinking
Rep Power: 0 2005 civic ex sedan 5 speed check engine light blinking
When I turn the car on (not started) my check engine light will stay on for a couple of seconds and blink 5 times and then go off. My car does seem to make a weird whistling noise when I give it gas. I just had the transmission rebuilt 7/21/16 what could it be?
Rep Power: 131 Re: 2005 civic ex sedan 5 speed check engine light blinking
sounds normal to me, i think mine does the same but I don't sit in the car long enough without cranking it for the CEL light to turn off.
If it blinks while the car is running then you have problems.
Rep Power: 0 Re: 2005 civic ex sedan 5 speed check engine light blinking
No code on the computer. But it makes a whistle/tick noise when I give it gas. But when it idles it sounds fine
Do you have a CAI?
If you rev the engine in Park does it whistle? Only when moving and accelerating? Maybe a vacuum leak in the throttle body?
5 speed standard. And it's a factory stock intake. No cold air or short ram. And I don't know where to start with a hose leak
You don't have a hose leak until someone proves there's a hose leak.
You have a whistle noise complaint.
Figure out where the noise comes from.
What did your mechanic say the noise is?
Kkoestner
11-22-2015 04:50 PM
TheBhoyJay
11-20-2015 08:47 AM
damahark
10-28-2015 08:11 AM
