10 mm bolt snapped for thermostat
Rep Power: 0 10 mm bolt snapped for thermostat
Hello everyone, I replaced my thermostat today. After i replaced it i over tighten one of the bolts and snapped. Its on and does not leak. Is this something i should worry about? or get it fixed asap? Thank you all for your advice.
Re: 10 mm bolt snapped for thermostat
I would take it apart, extract (drill out) the broken chunk using a left-hand drill bit (so it will spin right out when the bit catches), then replace both bolts with new.
RIPSAW
07-14-2016 08:21 PM
Lihcas
06-13-2016 07:24 PM
Rekter
06-13-2016 06:01 PM
fvckbg
06-04-2016 01:57 AM
