Basic Battery question
Left my Civic with the headlights on for approx 90 mins at 5C outside temp whilst in an appointment. There was not enough juice to start the car on my return. Tried cranking it a fair number of times letting it rest every few goes.. got a jump-start off someone just came straight home.
What I'm wondering is :
Does this sound like a battery on it's last legs that I should definitely replace?
Is there a way to test the batteries performance with a multimeter?
To my limited knowledge that seems a bit quick to go flat, but it is 5C and most of my journeys have been short treks lately.
Re: Basic Battery question
How old is the battery? More than a few years? Better just get a new one.
There is no way to test the capacity of the battery with a voltmeter. You can test the voltage. If you have not charged it yet and find the voltage is below 10 volts, it's probably toast.
Usually once a battery has fallen below a certain voltage threshold you destroy the internal chemistry of the battery. You could try charging it and you may actually get it up to 13 or 14 volts, but the capacity could be totally gone and as soon as you try to use the battery the voltage will plummet.
Not sure of the battery age. I've had the car 20 months and it wasn't new then.
Great tip thanks !
After the drive home (7 miles?) I tested across the terminals (some hours later) and see 12.7v
DashCommand shows 12.2v
Tomorrow I will observe the voltage on the terminals whilst cranking, from my reading I understand it should not dip below 10v and should rise to 13.5-14v or so..
Great tip thanks !
1) Start car
2) Drive to autozone or other parts store
3) Tell parts-boy (liken to ****-boy..lol) you would like to have your battery, alternator and starter tested (no parts removed/all on car)
4) Report back here
4) Report back here
Mine won't last even 9 min. Still driving the car without replacing it.
if it charged back up to 12.7 and is starting the car fine i would just leave it
KalliGarri
09-04-2005 05:40 PM
KalliGarri
Texas
08-30-2005 03:34 AM
