Coolant and oil loss no overheat
Rep Power: 0 Coolant and oil loss no overheat
First and foremost, I'd like to apologize to you veterans if I overlooked search results and made a repost.
My 2001 Civic 5 speed is at 180,000 miles now and I've been noticing that my engine is burning or leaking quite a significant amount of oil and coolant.
I lose about 1.5 qt between a 5k mile oil change and I have to top off my coolant every month or so.
It took me a while to catch on to this situation and I drove the car with low oil and coolant for a while and the car never overheated and my temperature gauge never went past what's considered normal. I never blow out white or blue exhaust
Do I have a blown head gasket or a cracked head? I'm hoping it's none of these but I'm beginning to think my engine has been infected with the notorious disease.
Rep Power: 0 Re: Coolant and oil loss no overheat
Is your coolant overflow reservoir filling up or overflowing causing the coolant loss? If so it's likely the head gasket. Have you performed a compression test?
Received 1,440 Likes
Rep Power: 338 Re: Coolant and oil loss no overheat
RIPSAW
11-06-2015 04:36 AM
lilrob1213
37
06-29-2015 06:45 PM
civiic143
06-29-2015 06:15 PM
richgreene
06-19-2015 12:04 AM
06-02-2015 11:54 AM
