Turn Signals not working
Rep Power: 0 Turn Signals not working
2003 Honda civic, turn signals are not working, hazards are working. I replaced the relay, and the fuse is good. The signal doesn't even light up or click on the dash. What could it be?
Re: Turn Signals not working
Not necessarily, those are two completely independent systems that just happen to be inside the same housing.
A wiring diagram, a test light or voltmeter and a little time and knowledge would go a long way toward coming up with the correct solution.
I had the same problem with my 01, turned out to be the wires we're loose on the emergency flashers from a butchered radio installwould it would just lightly buzz when I put on the blinkers
civicPRODIGY
11-12-2001 09:32 PM
GhettoCivic
11-12-2001 03:15 PM
