MICU replacement question
Rep Power: 0 MICU replacement question
Hello Guys
There was a multi problem on my 2001 Civic
I changed MICU for another one.
All previous problems disappeared BUT
Now I have PARKING blocked.
There is no signal to solenoid to unlock when I press break pedal
So
How to re-programm new MICU? Or something wrong with him?
Thanx in advance
So
Thanx in advance
Re: MICU replacement question
Post/thread moved.
MICU is plug and play as far as your problem is concerned.
I suggest you double check you got all the connectors fully seated, and check all the fuses are in the correct holes
and you got all of the relays swapped into the new fusebox.
Was your new unit actually brand new?
Was it a used part?
If it was used, was it correct for your car? There may be dozens of different versions of the fusebox/MICU.
Was it a used part?
Rep Power: 0 Re: MICU replacement question
Thanx Guys
I have got it.
It was 01 pack for manual (standard) transmission. It does not have shift lock/unlock.
I change it for 02 pack for automatic and now its ok.
Thanx
I have got it.
Thanx
oneheadlight
04-29-2015 11:30 PM
thesushiboy
04-12-2015 02:54 AM
