Oooops - Huge Timing Belt Job No No
Old 06-27-2015
heath3000's Avatar
heath3000 is an unknown quantity at this point
So what's this timing belt job no no?
Turning the crank when the timing belt was not on.
Too bad I discovered this after the fact. I was changing timing belt because the car would only start if I disconnected the crank sensor, which is a classic sign that the timing is off.
So let's not dwell on how or why I managed to screw up or the fact that I'm an idiot. Instead I'm wondering if there is a way out of this mess.
I got to this point because as I was turning the crank (sigh) I noticed it got a bit tougher to turn. So I didn't force it, and did a little research. I tried to test the state of things by gently trying to turn the camshaft. It doesn't want to move. So, I know I've really screwed things up. I'm hoping I haven't already bent a shaft or something.
What should I do next? Call a wrecker? Lol. Hopefully it doesn't come to that. I've only got $850 or so into this Civic that I got used from someone who gave up on the car because they couldn't figure out how to replace the crank shaft sensor connector. Anyway...
Can anyone help?
Heath
P.S. Did I mention that I'm an idiot?
UPDATE: OK, so I think I may have it worked out (long story), and I've got the timing belt on and I believe it to be all timed well. I've turned the engine through 6 times and timing still looks good. My issue now is... how do I know if something is f**ked up in there? Would I hear it as I was turning the engine? Would I feel it? Is there something I can look for in the rocker arms as I'm turning?
Old 06-27-2015
Re: Oooops - Huge Timing Belt Job No No
If you have the timing belt installed and correctly timed, you could bolt the crank pulley on and do a compression test.
Old 06-27-2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
so maybe you think you bent a valve or two?? idk
IMO if you think the timing belt is on correct, run a compression test by hand (no starter, no ignition). but really check to see if the belt is on correctly first
good luck!
mattdoc
03-14-2017 12:10 PM
mrohitredd
18
05-14-2015 07:35 PM
MN-02-CivicEx
28
05-02-2015 09:11 PM
dano2005
04-14-2015 01:58 AM
Gunner
Engine DIY
10-06-2012 12:37 PM
Quick Reply: Oooops - Huge Timing Belt Job No No
