Cruise Control issue
Old 06-23-2015
CivicDaniel's Avatar
CivicDaniel is an unknown quantity at this point
I've checked the other cruise control threads and those seem to be a different issue than what I am experiencing.
I have a 2001 Civic. Recently, when cruise control is engaged the car will randomly decelerate and in some cases the cruise control will just cut off. This doesn't happen every time I use cruise control, but it happens more frequently these days.
The green cruise button light works. When engaged, the cruise control text lights up on the dash and the cruise will actually engage. So I don't think its a fuse issue (which seems to be the more common issue).
Any thoughts on what the issue might be?
Old 06-23-2015
CraigW's Avatar
Re: Cruise Control issue
Search this site.... it was 7th gen only at one time.
Too much slack in a cable comes to mind though.
Old 06-23-2015
So does a bad control unit, the usual lights remain on but it loses track of the speed.
Old 06-24-2015
Is there a way to test it without taking it to the dealer? Where is the control unit located in the car? Is it is to replace (assuming it needs to be replaced)?
Old 06-24-2015
CraigW's Avatar
Control unit: Sedan is near the drivers side, lower.
Old 06-24-2015
A dealer probably wouldn't (can't) test it. I don't think I have ever tried, I don't know there is any way to test it other than check every other component then try a known good unit if everything else tested good.
Where is anyone going to find a known good unit to try?
Read up on the symptoms people notice where the fix is a new cruise control unit. See if your symptoms match.
Also, the cruise systems can be entirely different between coupe and sedan. Please state your car details whenever you start a thread.
HTH
KronikScott
06-09-2015 08:00 PM
MamaBear2015
05-27-2015 12:04 PM
cukaracha
05-16-2015 02:11 PM
o0aznbboy0o
02-06-2002 06:14 AM
Civic316
Electronics
12-10-2001 12:03 PM
Quick Reply: Cruise Control issue
